Results 1 to 10 of 15
April 25th, 2003 01:21 PM #1
The engine alone runs good but i noticed that intermittently, the whole engine vibrates. This is quite noticeable at idling speeds. Is it caused by misfiring spark plug/s?
April 25th, 2003 02:11 PM #2
could be one of the reason. pwede rin na nasa A/C system. yung oto ko kasi before is ganun din. tapos may intermitent engine vibration. yun pala barado yung evaporator tsaka yung adjustment valve.
April 25th, 2003 03:42 PM #3could be one of the reason. pwede rin na nasa A/C system. yung oto ko kasi before is ganun din. tapos may intermitent engine vibration. yun pala barado yung evaporator tsaka yung adjustment valve.
- Mar 2003
- 91
April 26th, 2003 03:41 PM #5i think kailangan lang ng tune-up ng auto mo.. pa check mo nlang sa mechanic mo baka nung last time niyang ginawa ung auto meron siya ginalaw so pa check mo nlang sa kanya.. :D
April 27th, 2003 09:19 AM #6
malamang nga sparkplug, sabi nga ni buddyclub pa check/tune-up mo na lang.
April 27th, 2003 06:27 PM #7Originally Posted by colt45
September 28th, 2007 05:34 PM #9
aside from rough idling, are there any other symptoms of misfiring?
September 28th, 2007 06:34 PM #10
ganyan experience ko a few months ago. sira na pala yung isang HT wire ko. replaced it and readjusted the timing. ok na ulit.
madali lang naman i-DIY check eh. just pull the wires one at a time (only one at one time). when you pull a wire and hindi nagpalit (or very minimal lang ang change) ng takbo yung engine, either spark plugs nga yan or yung wire ang problem.
