Results 1 to 10 of 15
April 25th, 2003 01:21 PM #1
The engine alone runs good but i noticed that intermittently, the whole engine vibrates. This is quite noticeable at idling speeds. Is it caused by misfiring spark plug/s?
April 25th, 2003 02:11 PM #2
could be one of the reason. pwede rin na nasa A/C system. yung oto ko kasi before is ganun din. tapos may intermitent engine vibration. yun pala barado yung evaporator tsaka yung adjustment valve.
April 25th, 2003 03:42 PM #3could be one of the reason. pwede rin na nasa A/C system. yung oto ko kasi before is ganun din. tapos may intermitent engine vibration. yun pala barado yung evaporator tsaka yung adjustment valve.
- Mar 2003
- 91
April 26th, 2003 03:41 PM #5i think kailangan lang ng tune-up ng auto mo.. pa check mo nlang sa mechanic mo baka nung last time niyang ginawa ung auto meron siya ginalaw so pa check mo nlang sa kanya.. :D
April 27th, 2003 09:19 AM #6
malamang nga sparkplug, sabi nga ni buddyclub pa check/tune-up mo na lang.
April 27th, 2003 06:27 PM #7Originally Posted by colt45
September 28th, 2007 05:34 PM #9
aside from rough idling, are there any other symptoms of misfiring?
September 28th, 2007 06:34 PM #10
ganyan experience ko a few months ago. sira na pala yung isang HT wire ko. replaced it and readjusted the timing. ok na ulit.
madali lang naman i-DIY check eh. just pull the wires one at a time (only one at one time). when you pull a wire and hindi nagpalit (or very minimal lang ang change) ng takbo yung engine, either spark plugs nga yan or yung wire ang problem.
As long as it is valid, bring a printed copy. Then, they will ask you to use one of the PCs there...
