Results 1 to 15 of 15
    The engine alone runs good but i noticed that intermittently, the whole engine vibrates. This is quite noticeable at idling speeds. Is it caused by misfiring spark plug/s?
    could be one of the reason. pwede rin na nasa A/C system. yung oto ko kasi before is ganun din. tapos may intermitent engine vibration. yun pala barado yung evaporator tsaka yung adjustment valve.
    Isn't it that a clogged evaporator causes low cooling?
    di kaya sa HT wires mo
    Mar 2003
    i think kailangan lang ng tune-up ng auto mo.. pa check mo nlang sa mechanic mo baka nung last time niyang ginawa ung auto meron siya ginalaw so pa check mo nlang sa kanya.. :D
    malamang nga sparkplug, sabi nga ni buddyclub pa check/tune-up mo na lang.
    Quote Originally Posted by colt45
    check your high-tension wires... especially if you are using aftermarket wires. Reinstall your stock wires and check again.
    thanks for all the suggestions.:D
    aside from rough idling, are there any other symptoms of misfiring?
    Aug 2003
    ganyan experience ko a few months ago. sira na pala yung isang HT wire ko. replaced it and readjusted the timing. ok na ulit.
    madali lang naman i-DIY check eh. just pull the wires one at a time (only one at one time). when you pull a wire and hindi nagpalit (or very minimal lang ang change) ng takbo yung engine, either spark plugs nga yan or yung wire ang problem.
    spark plus could be one of the reasons ... pero marami rin nang gagaling and vibrating ...
    try mo tingnan kung kailangan linisin yung throttle body ng car mo usually madumi or you can check you air cleaner ...
    high tension wire can also be one problem ... but usually pag brittle or my open wires usually and signs na sira siya ... one way to test if your gutsy enough tangalin mo yung high tension wire slightly lang and you can hear sparking ... if you can hear it okay pa yan .....
    maraming reasons and depende rin sa cars please give more details
    Banawe Auto Supply
    regy
    bumabagsak lang idling niya actually pag nag-brabrake ako. ek '96 vti nga pala car ko. pero i think due na din iyong change sparkplugs ko
    Nov 2003
    idling problems on hondas are solved through the intake manifold cleaning and iacv cleaning.
    ^i already cleaned it myself earlier this year. could it be possible that it got dirty again in such a short span of time
    Nov 2003
    probvably not but it can't hurt to clean it again. if ayaw maayos then normally it requires replacing the sensor na.
misfiring spark plugs?
