Results 11 to 19 of 19
November 21st, 2006 08:31 AM #11
speedyfix: ah unga naman, "BRAKE"
m_ron: heat shield po ba un? nde backing plate
batang_raon14: ganun ba, napaayus mo?
katsudon_ph: sir napaayus mo po ba ung hydrolic cylinder of the brake.. the one with gasket.., nwala ung tunog?
- Sep 2005
- 103
November 21st, 2006 09:44 AM #12Baka hindi na pantay ang pudpud ng rotor kaya may part na dun lang sya tumutunog, have it re-faced.
or maybe stuck up ang piston. maybe needs some cleaning. have the entire braking system be check na rin.
November 21st, 2006 10:53 AM #13
if it's not a backing plate then definitely not a heat shield rather more appropiately a splash shield
November 21st, 2006 01:29 PM #15
i think backing plate. bec there is nothing in the hub assembly that needs heat protection. in the first place, it is subjected to continuous heat while running.... it happened to my car before. i had the ball bearing replaced and the mechanic bent the plate towards the rotor disc. so it grinded the rotor and damaged it. still is usable pero meron lubog on the inner side of the rotor disc. maliit lang ang clearance nito. slight bent or misalignment in installation, it will already touch the disc.
November 21st, 2006 09:09 PM #16
well anyways i'll just check the whole brake system starting with the mentioned parts.. backing plate and so on.. thanks guys
- Aug 2004
- 243
November 21st, 2006 10:37 PM #17deathlance: naayos naman nilinis then pinalitan ng brake cyclinder gasket ata tawag nun brand senkyu.. pero pag dinala mo sa case, they told me too replace the whole assembly which is expensive.
naalis po ung tunog..
November 22nd, 2006 12:03 AM #18
deathlance: Natanggal ung sound samen by changing the brake cylinder gasket rin. Same as katsudon's.
November 22nd, 2006 11:11 AM #19
batang_raon14,katsudon_ph: nde na ung hydraulic brake cylinder? nor the backing plate, so ang brake cylinder gasket pla ang may sala, kanu ba un? san mura at maayus mag pagawa di ko kasi alam baka madaya nila ako
Though not on a people carrier like the Innova, I have Yokohama es32 equipped on my Sylphy since...
Finding the Best Tire for You
