Results 1 to 19 of 19
    Sep 2005
    Baka hindi na pantay ang pudpud ng rotor kaya may part na dun lang sya tumutunog, have it re-faced.
    or maybe stuck up ang piston. maybe needs some cleaning. have the entire braking system be check na rin.
    if it's not a backing plate then definitely not a heat shield rather more appropiately a splash shield
    Sep 2006
    Quote Originally Posted by t2erns View Post
    not a splash shield,maybe mud guard.
    i think backing plate. bec there is nothing in the hub assembly that needs heat protection. in the first place, it is subjected to continuous heat while running.... it happened to my car before. i had the ball bearing replaced and the mechanic bent the plate towards the rotor disc. so it grinded the rotor and damaged it. still is usable pero meron lubog on the inner side of the rotor disc. maliit lang ang clearance nito. slight bent or misalignment in installation, it will already touch the disc.
    Sep 2006
    well anyways i'll just check the whole brake system starting with the mentioned parts.. backing plate and so on.. thanks guys
    Aug 2004
    deathlance: naayos naman nilinis then pinalitan ng brake cyclinder gasket ata tawag nun brand senkyu.. pero pag dinala mo sa case, they told me too replace the whole assembly which is expensive.
    naalis po ung tunog..
    deathlance: Natanggal ung sound samen by changing the brake cylinder gasket rin. Same as katsudon's.
kaskas sound sa breaks
