Results 31 to 40 of 54
October 16th, 2006 12:22 PM #32
ahh...for recklus pala.
arvic, pwede na yan...lapit na ma set :kodak: EB.
October 16th, 2006 04:28 PM #33
October 16th, 2006 04:32 PM #34
super black ba tint mo?
tanggal na yan para makita driver...ang foooogggeeeee.
October 16th, 2006 04:50 PM #35
October 17th, 2006 08:52 AM #37
Mga sir... another observation, ngyari na din po ba sanyo yung 2 start ayaw niya mag start then sa pang 3rd tsaka nag start.... 1 whole day ko lng po sya di na gamit... yung batt nya eh less than a year pa.... worried kc ako.... may same incident po ba kyo nito?
October 17th, 2006 03:38 PM #38
napa check mo na? baka sa camshaft sensor lang yan.
oist! yung :kodak: eb this sunday sa MOA. 3PM ;)
October 17th, 2006 04:01 PM #39
Mine's always had that problem, right from the start. On cold days, or after it's been sitting a while, it takes two or three clicks to start the engine. Changing the battery helped a little. Mine still had the green indicator, but I think it wasn't strong enough.
Halos lahat kami na naka-RS sa fordclubph naka-experience ng ganyan. Talagang grouchy ang starter, clutch at gearshift pag malamig yung makina.
Best thing to do is use it for an hour or so at least every other day, to keep the engine loose and the battery charged. Kawawa si jimboy (protegetech.org), they left their Lynx RS showcar for too long at Kid Audio (over a year, I think), and now the engine's stuck up. Ouch.
Other things to watch for, but which are perfectly normal:
Clutch and shifter don't feel quite right when you drive early in the morning. Feel okay after about 15 minutes of driving.
Clutch gets hard to use in heavy traffic.
Shifter is notchy when cold, grinds a bit if you try to shift too fast or when you're in very hot traffic.
This is because the stock gear oil and gears have a narrow optimal temperature range. If they're too cold or too hot, they start getting grouchy. Best solution for this is better synthetic gear oil, preferably Motul. Mobil1 is supposedly incompatible with our synchros.
Sabi ko nga before, di perfect ang Lynx RS, pero sa character lang niya yun. She doesn't like standing still for too long, she doesn't like traffic or driving slowly... she prefers winding mountain roads with the windows open...
Oh, and use your sunroof when you can. Sayang lang na meron kung di niyo bubuksan...Last edited by niky; October 17th, 2006 at 04:12 PM.
October 18th, 2006 09:36 AM #40
10 years validity ko yehey , kaya lang sa june pa makukuha physical card :twak2: :rolleyes:
