Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 62
    #21
    as a side track, don't u notice that the engine filled with coolant, cools down slower, once the engine has been shut down, than the one filled with plain water ? or is this occuring in my case only ?
    #22
    Quote Originally Posted by theveed
    XTO: That's not exactly true, while cooling capacity may be close (similar, due to pressurized system), water alone will not provide lubricity to the water pump.
    Common sense lang naman, car manufacturers wouldn't REQUIRE all cars to be filled with the proper coolant mixture if it's not optimal.
    People tend to draw their own conclusions din kasi usually based on lowering cost alone.
    yes it is a common sense to create our own conclusion based on our own observation and experience.
    #23
    Quote Originally Posted by red888
    Just a guess...
    the evaporating water (no coolant) helps in the quicker cooling process since it has a lower boiling temperature.
    Dec 2003
    #24
    those red ultra long life coolant seem to be the one's that need changing after 100k kms..like the caltex long life coolants
  5. FrankDrebin Guest
    #25
    Speaking of coolant, may available ba na Evans NPG-R Waterless Coolant sa atin?
    http://www.thunderracing.com/catalog...&vid=18&pcid=5
    #26
    caltex na red coolant lang gamit ko. Ok naman sya.
    #27
    Quote Originally Posted by xto
    Agree, whether or not the personal conclusion is valid or correct is another matter.
    #28
    Extended Life Coolant (N) - RED
    Extended Life Coolant Pre-Mixed 50/50 -Orange
    http://www.caltex.com.au/products_sp...ail.asp?id=318
    Hmm, meron kaya nakakaalam ng price ng mga ito? Parang gusto ko yun pre-mix (tamad magtimpla).
    Feedbacks
    Nov 2003
    #29
    5 liters premixed motul inugel coolant is 1400 fyi
    Apr 2006
    #30
    kung gusto mo makatipid, bili ka ng whiz coolant sa cash & carry. P150 petot lang per liter. coolant and anti-rust na sya. made in usa. actual location is inside the building where mercury drugstore is. it claims its designed to minimize/eliminate those deposits that accumulate from some formulas of other coolants. i used to use whiz in early 1990s pero switched to peak kasi mas mura noon. ngayon, whiz is cheaper na.
    kung P300 per 2 years ang gastos mo, laking tipid nun versus spending for radiator replacement (thousands of petot). i never had to change radiators on 4 cars because i take preventive maintenance on them. not to mention the hassle kung mag-overheat yung kotse due to radiator problem. hope this helps.
    Apr 2006
    #31
    Quote Originally Posted by buknoy2002
    me nabili ako coolant sa blade...
    Peak Coolant, P199 per liter , blue bottle made in USA.
    better kaya ito sa prestone or caltex?
    maganda ang peak. been using it til now na mas mura ang whiz.
    #32
    mazda2, kelangan pa bang magpalit ng coolant every 30kms? kelangan idrain then refill ng bagong coolant? ano ginawa mo sa oto mo?
    Apr 2006
    #33
    oo nga ..kailangan ba idrain ang tubig..or top up na lang?...
    Nov 2003
    #34
    drain and replace. pero use the same kind as much as possible.
    #35
    boss speedyfix, 30t kms na ko next pms ko. sabihin ko sa casa, drain ang replace ang coolant?
    Nov 2003
    #36
    sa 40k pa dapat.
    Sep 2005
    #37
    bumili ako ng Whiz, 120 lang sa ace. hope magawa ko yung draining and replace coolant sa rad ko next week. =)
    Jan 2003
    #38
    puroy
    yung whiz na P120 e 1liter ba?
  19. FrankDrebin Guest
    #39
    Quote Originally Posted by pepengtom
    Ikaw na lang ang mag-drain. Nakatipid ka pa. ;)
    #40
    Quote Originally Posted by FrankDrebin
    ask ko lang po kong kaylan ba dapat magpalit ng tubig/coolant ng radiator? TIA
how important is coolant?
