as a side track, don't u notice that the engine filled with coolant, cools down slower, once the engine has been shut down, than the one filled with plain water ? or is this occuring in my case only ?
yes it is a common sense to create our own conclusion based on our own observation and experience.Originally Posted by theveed
Just a guess...Originally Posted by red888
the evaporating water (no coolant) helps in the quicker cooling process since it has a lower boiling temperature.
those red ultra long life coolant seem to be the one's that need changing after 100k kms..like the caltex long life coolants
Speaking of coolant, may available ba na Evans NPG-R Waterless Coolant sa atin?
http://www.thunderracing.com/catalog...&vid=18&pcid=5
Agree, whether or not the personal conclusion is valid or correct is another matter.Originally Posted by xto
Extended Life Coolant (N) - RED
Extended Life Coolant Pre-Mixed 50/50 -Orange
http://www.caltex.com.au/products_sp...ail.asp?id=318
Hmm, meron kaya nakakaalam ng price ng mga ito? Parang gusto ko yun pre-mix (tamad magtimpla).
Feedbacks
kung gusto mo makatipid, bili ka ng whiz coolant sa cash & carry. P150 petot lang per liter. coolant and anti-rust na sya. made in usa. actual location is inside the building where mercury drugstore is. it claims its designed to minimize/eliminate those deposits that accumulate from some formulas of other coolants. i used to use whiz in early 1990s pero switched to peak kasi mas mura noon. ngayon, whiz is cheaper na.
kung P300 per 2 years ang gastos mo, laking tipid nun versus spending for radiator replacement (thousands of petot). i never had to change radiators on 4 cars because i take preventive maintenance on them. not to mention the hassle kung mag-overheat yung kotse due to radiator problem. hope this helps.
maganda ang peak. been using it til now na mas mura ang whiz.Originally Posted by buknoy2002
mazda2, kelangan pa bang magpalit ng coolant every 30kms? kelangan idrain then refill ng bagong coolant? ano ginawa mo sa oto mo?
boss speedyfix, 30t kms na ko next pms ko. sabihin ko sa casa, drain ang replace ang coolant?
bumili ako ng Whiz, 120 lang sa ace. hope magawa ko yung draining and replace coolant sa rad ko next week. =)
Ikaw na lang ang mag-drain. Nakatipid ka pa. ;)Originally Posted by pepengtom
ask ko lang po kong kaylan ba dapat magpalit ng tubig/coolant ng radiator? TIAOriginally Posted by FrankDrebin
