mga sir, yung lite ace namin nag wiwigle pag 40-50 na ko,bkit kaya gnun??
ilan taon na iyun lite ace mo?
mas maganda ipacheck mo sa talyer or sa casa, its possible worn na iyun following: ball joint, idler arm/pitman arm, tie rod end, suspension bushing, struts and shock absorber...
improper wheel alignment...
loose wheel bearing...
or simply low tire pressure lang...
madaming reason for wiggles eh... it can be a simple thing as uneven or oblong tires or busted suspension parts.
better yet if you consult your reliable suspension expert.
if you are in makati or south area, bukas na daw ang cruven...
