no its not.
under regular load even if you have an audio system you do not need a cap. You only need a cap for transient loads. the cap is hooked between a battery and amp, it doesn't affect any other electrical equipment other than what is hooked up to the cap.
grounding kits simply allows less resistance for the current to flow due to thicker gauges.
