Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 78
    #41
    no its not.
    under regular load even if you have an audio system you do not need a cap. You only need a cap for transient loads. the cap is hooked between a battery and amp, it doesn't affect any other electrical equipment other than what is hooked up to the cap.
    grounding kits simply allows less resistance for the current to flow due to thicker gauges.
    Sep 2004
    #42
    Quote Originally Posted by theveed
    no its not.
    hmmm di ba po merong mga "voltage regulators" na you can buy daw that will stabilize the voltage daw po, is that different?
    #43
    Your alternator should do that. Unless it's shot, you shouldn't have to worry about it.
    Aug 2003
    #44
    yung 4 gauge wire....parehas po ba ng kapal ng red wire ng ampli yan?
    #45
    Jeep: Amp wires can be anywhere between 0 gauge to 12 gauge, also, be wary of wires na gawa dito or china, the insulation may be very thick, but the actual copper wire is very thin.
  6. #46
    Power Cable/Wires available in Raon are gauge 8. Deeco is selling gauge 12 speaker wires,these babies are thick * 70/meter medyo pricey.
    Aug 2003
    #47
    huhuhu nagulo na hehehe :D
    ano po maganda gauge para dito?
    basta sabihin mo lang yung gauge sa mga electrical shops?
    tnx
  8. #48
    8 gauge will do, 4 gauge will be better. Hirap lang maghanap ng magandang 4 gauge wires dito, available yan sa mga automotive shops or electrical shops, preferably buy the 4 gauge power cables for audio.
    Aug 2003
    #49
    may nakagawa na po ba para sa diesel? saan po grounding points ng diesel engines?
    crosswind po...tnx ;)
    #50
    Jeepcruizerph: Kahit anong oto, basta gumagamit ng battery at alternator hehe.
    Oct 2003
    #51
    meron akong nakitang grounding kit sa automotive section ng hardware sa landmark level 3. post ko dito yung pix. cost around 750pesos. dunno what gauge is the wire is though.
    Aug 2003
    #52
    hehe :D
    eto po kasi na search ko sa net para sa gasoline:
    1) Negative batt terminal to chassis, 2) Negative batt terminal to distributor, 3) Distributor to intake manifold, 4) Intake Manifold to alternator, and, 5) Alternator to chassis.
    wala po kasi ako distributor lol
    di ko alam kung pwede sa intake manifold ko sobrang lakas ng vibration ng mga diesel
    yung sa alternator po ba kahit saan basta may bolt ng alternator?
    ang ganda po ng nakita kong grounding kit sa Liberty Duty Free inside clark stainless circle with 5 grounding points.
    1.2k ang price...mahal ba?
    Jan 2004
    #53
    Quote Originally Posted by zechs
    i saw it too. mukhang ok e. pero sir speedy, pa PM din ako ng price nung grounding kits mo. thanks!
    #54
    Quote Originally Posted by Jeepcruizerph
    Jeepcruizerph, binili mo ba? meron pa kaya nyan sa Liberty ngayon?
    Signature
    Nov 2003
    #55
    ubus na yung grounding kits ko. sorry!
    #56
    pasensiya na po pero para saan
    po ang grounding kits?
    ano po ang noticeable effects
    ng meron nito?
    magkano po ito?
    meron po bang sasakyan
    na binabagayan nito?
    thanks in advance?
    Jul 2005
    #57
    its noticeable sa electrical flow ng auto mo. masmaganda smooth kung baga but most of all pampaganda ng engine compartment. RED WIRES are grounding kit
    #58
    habang nakaandar at naka on ang head lights..den pagka on ko ng aircon medyo nag didim ng konti yung head lights ko..epekto po ba yun ng poor grunding?
    #59
    OT yata ang sagot ko pero, I hope this help.
    If your headlights go back to normal after a few seconds then I think this is normal. Aircon start-up really require a huge power from your battery. However, if your headlights doesn't return to normal then, check your battery. I guess you lack sufficient power to drive all your electrical requirement.
    Mar 2005
    #60
    Sorry, i up ko lang ulit. Meron na ba dito sa forum na nagtry maglagay ng grounding kit sa Diesel? I am planning to on Isuzu pikup pero gusto ko munang humingi ng feedback sa mga actual users (diesel rides). Salamat sa feedback.
Grounding kits and DIY grounding.
