Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 78
  1. #21
    speedyfix, pa pm din ng price, and wire size na gamit. TY.
    Aug 2003
    #22
    this is the negative ground kit install that speedyfix's shop did on my vehicle several months ago.
    it is the neon green cable from the battery terminal. unseen in the photo are the points to which the cable terminals were bolted to.
    malinis no?
    immediate effects of the install were:
    - better a/t shifting response
    - engine ran smoother
    - brighter headlights
    - a brighter sound quality on my stock (lang) car audio system
    Dec 2003
    #23
    Nung pumunta ako sa Roadstar Alabang dati hindi nila alam ang grounding kit..
    Jan 2004
    #24
    sir speedy,
    pa pm din po ng price. thanks!
    #25
    ginawa ko dati sa corolla ko (DIY lang) laking improvement sa sounds and lights talaga. It's not an upgrade per se naman, but usually kung naluluma yung car tapos napaka humid pa dito satin, madaling macorrode yung mga wires na exposed.
    Shouldn't we apply some non-corrosive gel sa terminal para di macorrode? O gold plated na to?
  6. #26
    to add to theveeds query
    from negative to body, kailangan bang iscrap off ang paint sa body?
    #27
    ang sabe dati sa akin nun kinuhaan ko ng battery. isa linya lang ng ground wire na makapal pwede na daw..
    Feb 2005
    #28
    hope this helps
    #29
    ILD: Usually walang paint na yung OEM mounts. But kung gagawa kang bagong grounding point, then of course, you should.
    #30
    Quote Originally Posted by speedyfix
    we've got a set in the shop
    how much is the grounding kit? my car is honda civic vtec3 2001 thanks
    #31
    Quote Originally Posted by box_type
    hope this helps
    thanks sa diagram i like option 2. might go for that
    May 2005
    #32
    mga car gurus para san ba ang grounding kit at voltage stabilizer? is this the same with the headlight relay?
    Nov 2003
    #33
    nope, very different. the relay allows you to use higher wattage bulbs safely without frying the stock wires/sockets.
    grounding kits are used to promote better circulation of electricity throughout the car.
    May 2005
    #34
    sir speedyfix...
    pwede pa PM naman ng price ng grounding kit nyo ..at kung sama na install doon
    TIA
    Nov 2003
    #35
    i just ran out dude, will try to order and pm you nalang when the new sets arrive.
    May 2005
    #36
    no problem ,sir speedy
    thanks again
    Aug 2003
    #37
    up ko lang po, saan po grounding points ng diesel engine?
    para po sa crosswind...maraming salamat po
    Sep 2004
    #38
    Sa mga ibang audio enthusiast, they clean up (and stabilize) their electrical by putting in large capacitors (sometimes as large as 1 farad!) ...
    So, grounding kit + capacitor ... magkano kaya yung ganun?
    #39
    ALbert: Caps don't stabilize current, it merely stores current in an event of sudden voltage consumption (usually when an amp plays a deep bass note).
    Think of it as a water tank.
    Sep 2004
    #40
    Quote Originally Posted by theveed
    di po ba same lang 'yon? Kung fluctuating yung voltage mo, meaning po may drops and peaks sa voltage level, the caps will level that off for you by supplying the needed juice back into (or getting from) the electrical? Parang yung sa mga voltage rectifiers sa electronics? Clarify lang po, medyo akala ko po kasi ganun yun?
    pero tama po kayo, it won't stabilize the current ... just the voltage lang po.
Grounding kits and DIY grounding.
