Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 78
    ALbert: Caps don't stabilize current, it merely stores current in an event of sudden voltage consumption (usually when an amp plays a deep bass note).
    Think of it as a water tank.
    Sep 2004
    Quote Originally Posted by theveed
    di po ba same lang 'yon? Kung fluctuating yung voltage mo, meaning po may drops and peaks sa voltage level, the caps will level that off for you by supplying the needed juice back into (or getting from) the electrical? Parang yung sa mga voltage rectifiers sa electronics? Clarify lang po, medyo akala ko po kasi ganun yun?
    pero tama po kayo, it won't stabilize the current ... just the voltage lang po.
    no its not.
    under regular load even if you have an audio system you do not need a cap. You only need a cap for transient loads. the cap is hooked between a battery and amp, it doesn't affect any other electrical equipment other than what is hooked up to the cap.
    grounding kits simply allows less resistance for the current to flow due to thicker gauges.
    Sep 2004
    no its not.
    hmmm di ba po merong mga "voltage regulators" na you can buy daw that will stabilize the voltage daw po, is that different?
    Your alternator should do that. Unless it's shot, you shouldn't have to worry about it.
    Aug 2003
    yung 4 gauge wire....parehas po ba ng kapal ng red wire ng ampli yan?
    Jeep: Amp wires can be anywhere between 0 gauge to 12 gauge, also, be wary of wires na gawa dito or china, the insulation may be very thick, but the actual copper wire is very thin.
  8. #8
    Power Cable/Wires available in Raon are gauge 8. Deeco is selling gauge 12 speaker wires,these babies are thick * 70/meter medyo pricey.
    Aug 2003
    huhuhu nagulo na hehehe :D
    ano po maganda gauge para dito?
    basta sabihin mo lang yung gauge sa mga electrical shops?
    tnx
  10. #10
    8 gauge will do, 4 gauge will be better. Hirap lang maghanap ng magandang 4 gauge wires dito, available yan sa mga automotive shops or electrical shops, preferably buy the 4 gauge power cables for audio.
    Aug 2003
    may nakagawa na po ba para sa diesel? saan po grounding points ng diesel engines?
    crosswind po...tnx ;)
    Jeepcruizerph: Kahit anong oto, basta gumagamit ng battery at alternator hehe.
    Aug 2003
    hehe :D
    eto po kasi na search ko sa net para sa gasoline:
    1) Negative batt terminal to chassis, 2) Negative batt terminal to distributor, 3) Distributor to intake manifold, 4) Intake Manifold to alternator, and, 5) Alternator to chassis.
    wala po kasi ako distributor lol
    di ko alam kung pwede sa intake manifold ko sobrang lakas ng vibration ng mga diesel
    yung sa alternator po ba kahit saan basta may bolt ng alternator?
    ang ganda po ng nakita kong grounding kit sa Liberty Duty Free inside clark stainless circle with 5 grounding points.
    1.2k ang price...mahal ba?
    Quote Originally Posted by Jeepcruizerph
    Jeepcruizerph, binili mo ba? meron pa kaya nyan sa Liberty ngayon?
    Signature
    Oct 2003
    meron akong nakitang grounding kit sa automotive section ng hardware sa landmark level 3. post ko dito yung pix. cost around 750pesos. dunno what gauge is the wire is though.
    Jan 2004
    Quote Originally Posted by zechs
    i saw it too. mukhang ok e. pero sir speedy, pa PM din ako ng price nung grounding kits mo. thanks!
    Nov 2003
    ubus na yung grounding kits ko. sorry!
    pasensiya na po pero para saan
    po ang grounding kits?
    ano po ang noticeable effects
    ng meron nito?
    magkano po ito?
    meron po bang sasakyan
    na binabagayan nito?
    thanks in advance?
    Jul 2005
    its noticeable sa electrical flow ng auto mo. masmaganda smooth kung baga but most of all pampaganda ng engine compartment. RED WIRES are grounding kit
    habang nakaandar at naka on ang head lights..den pagka on ko ng aircon medyo nag didim ng konti yung head lights ko..epekto po ba yun ng poor grunding?
Grounding kits and DIY grounding.
