Same lang ba quality ng nabibiling grounding kits? or mas maganda pag diy?
effectiv din ba yung mga grounding kits?
i think what you pay for the grounding kits is worth the price. mas maganda tingnan and sure ka of the quality.
depende sa gagawa kung diy. basta complete ka sa parts and tools. you'll need a crimping tool for the terminals, plus for the parts the wires, ring terminals, heat shrink insulation. sa akin diy lang, mas ok hindi na erratic idling, mas maliwanag headlights.
medyo OT: can you guys take a look: http://z-stab.com/
parang voltage stabilizer lang. pwede kayang add-on to sa negative ground kit? o i-diy din?
as stated in the website, it's just a capacitor. the idea must have come from the capacitor installed across the pos and neg terminals of a ac/dc transformer to convert the wave output from fluctuating pos-zero sinusoidal wave (such as that produced by a vehicle alternator) to a flat waveform (like that produced by a battery).
BUT the question is, should this not be installed across the alternator terminals and not across the battery terminals? you will still have the spikes across the alternator terminals even with this gadget installed as in the picture, so then the whole vehicle electrical system will still have those spikes. the output from the battery is already constant and flat so why put it there? wrong placement of a good idea imho.
according to what i read (eto din ginawa ko):
=alternator
=distributor
=chassis
=valve cover
=TB
Nung pumunta ako sa Roadstar Alabang dati hindi nila alam ang grounding kit..
chassis
cylinder block or transmission
intake manifold
cylinder head...
sa mga ganyan ko kinabit
eto po reference ko...
http://www.geocities.com/rshph2000/ground.html
di ako nagkabit sa A/T since m/t tsikot ko...![]()
sa akin negative terminal ng battery to car body, engine block, transmission (A/T), throttle body, negative terminal ng alternator.
uy, mukhang talagang kelangan ko ng pasyalan yung shop nyo sir. pwedeng pa-PM kung magkano yung 1 set? :DOriginally Posted by speedyfix
how much is the grounding kit? my car is honda civic vtec3 2001 thanksOriginally Posted by speedyfix
