Results 21 to 30 of 32
September 19th, 2005 12:36 PM #21
david,
simple answer lang yan. the fuel pump needs to pressurize the lines kasi overnight nawawalan ng pressure.
wanna test this theory? ganito.. after you've started out for the day, you say 1-click start nalang, right? OPEN YOUR GAS TANK. sisingaw yung pressure buildup. close the tank again. i bet hindi na siya 1-click, you'll have to do the 3-second delay bit again. but in my experience, hindi dapat kailangan i-bomba yung gas pedal: the engine computer will automagically give a super-rich mixture (equivalent sa pagbobomba) when cranking. maybe your IAC valve (ISC or servo..) and/or throttle body needs cleaning. gummed-up IAC means trouble when the ECU wants it wide-open (e.g. when cranking) and some rough idling.
normally EFI cars run rich naman eh, so a gasoline smell isn't abnormal. i've smelled gasoline around my car's back end for a couple years now. wala namang sumabog, and my fuel mileage is just about right for a car of this age and displacement.
September 19th, 2005 12:55 PM #22
orly: actually, kahit naopen yung tank ok lang sya since pag nagparefuel ako one click nadin sya agad.
Manilis po ang aav/throttlebody etc ko kalilinis lang sa casa.
September 19th, 2005 12:59 PM #23
hm that's indeed somewhat strange... baka kahit open tank there's enough fuel in the fuel *lines* that hasn't drained out. i'd hardly call it a deal-breaker ;) lalo na kung ano-anong gastos pa ang aabutin to find the problem.. pero the simple stuff like fuel filter, ok lang siguro..
SiRaNeko
- Jan 2003
- 973
September 19th, 2005 09:06 PM #24David,
parang lahat ng yan dinaanan ko na this year. ang difference lang, carb yung kia ko.
di ko rin ma pinpoint kng ano dahilan.
basta ngayon one click na cya pag morning. no more waiting sa on position. pero pag nag start and you immediately press the gas pedal, namamatay. so dapat hayaan mo sya mga 10-15 secs bago depress gas pra tumaas idling.
September 19th, 2005 09:19 PM #25
Naisip ko din sabi ni Orly, hehe, paminsan it's not worth looking for it if it doesn't affect you :P Pero takot ko kasi baka lumaki at magkasunog...
buknoy: weird din yun ah hehe
- Jul 2017
- 3
October 11th, 2018 08:44 AM #26
October 11th, 2018 09:48 AM #27
Sakit sa ulo nyang cold start hard start na yan, naranasan ko yan nakaka 5 click na ako pati lang naandar. Ginawa ko para maalis yan pinalitan ko spark plug at hinanap ko yung butas na hose na may natagas na tubig, nawala naman.
- Jul 2017
- 3
October 11th, 2018 11:29 PM #28
October 12th, 2018 01:54 AM #29
- Jul 2017
- 3
October 12th, 2018 07:25 AM #30
I agree. travelling by train is always the fastest way to travel. kami din dati sa Bangkok, we...
Makati Subway. Completion date: 2025
