Results 21 to 30 of 54
Tsikot Member Rank 5
- Nov 2003
- 3,849
October 19th, 2006 11:32 PM #23pads shouldn't be that expensive. maybe 1/3rd to 1/2 of that lang max for very decent brands na.
Tsikot Member Rank 4
- Jun 2006
- 2,605
October 26th, 2006 01:40 PM #24My dad decided to send the car to Autohaus.
Taked to the SA. He wants to change oil and filter, change fuel filter and air filter, replace coolant and brake fluid, check brake pads and sensors, alternator and fan belts.
I told him to go and change oil and filter but do not change brake fluid and coolant as it was last replaced by them last Sept 2005. Just top up if needed. He claims that according to BMW Phil, it needs to be replaced yearly bec of our climate and road conditions. Is this true or BS? Personally I think yearly change of coolant and brake fluid is to short, specially with dealer prices. What is your opinon?
Also told him not to replace parts and fluids without getting go signal from me.
October 26th, 2006 03:57 PM #25He claims that according to BMW Phil, it needs to be replaced yearly bec of our climate and road conditions. Is this true or BS?
Zombie
- Aug 2006
- 728
October 26th, 2006 07:07 PM #26sir for the brake fluid: it's true that our environment is totally different from Bavaria, but there should be a procedure for them to say that (a visual inspection should be minimum)
Autotechnika actually uses a handheld brake fluid tester that checks if your fluid is still functioning properly.
Shameless plug: We at Autotechnika - Fort can service BMWs (we also offer upgrades/aftermarket parts).
For the coolant: You don't need that unless there's signs of rust (if there is, you'd need a flush too)
Shameless plug again: we have lav'ramon cooling system cleaner.
- Jun 2006
- 2,605
October 26th, 2006 07:22 PM #27Yep, that what I felt when he said that brake fluid and coolant needs to be replaced. More so since the car is not used that much ave of 10,000 kms a year.
Sorry if OT. I did not know that there is a brake fluid tester. I do know that there are coolant testers. I saw one before when I was in Canada. Looks like a small pump with a guage that tells you the effective temp range of the coolant. Is it available locally?
October 26th, 2006 08:59 PM #29
userfriendly's dad wants to get rob again.Anyway any decent shop can do the maintenance on your bmw.No need for a special tools,you can even do it yourself.
October 26th, 2006 09:10 PM #30
Baka iisa lang ang owner ng BMW, Rapide at Zafra. :lol:
Tapos ang tire supplier nila ay Miller.
