Results 41 to 50 of 60
Tsikot Member Rank 3
- Oct 2003
- 699
September 13th, 2006 06:09 PM #41
September 13th, 2006 06:17 PM #42
September 13th, 2006 06:30 PM #43
I was under the same impression myself
We have a nissan sentra (AT) that waded the flood in traffic in DRIVE mode only (foot on the brake while the car moves slowly; cant rev high). Did not feel the engine stalling/choking unlike in our MT vehicles where you have to get ready to press the accelarator once you feel the engine is about to stall. I assumed that the ECU automatically adjusted the idling
September 13th, 2006 09:34 PM #44
- Jul 2005
- 430
September 13th, 2006 10:03 PM #45
September 13th, 2006 10:11 PM #46
First off, know what the lowest point of water entry is. Usually, this is thru the top hole of the dipstick or through the transmission breather (basically a metal or rubber hose that sticks out of the transmission). On a Nissan Sentra, the breather extends up to the engine compartment so its a non-issue. On some vehicles, it's nothing more than a straw sticking out of the transmission body.
As with any transmission type, maintain a slow and steady speed when crossing. Avoid a very tall 'bow wave' or water crest in front of the vehicle.
Do not stop midstream.
Avoid crossing water by driving 'upstream' (driving the opposite direction the water is going) to it. It's easier to drive 'downstream' or just perpendicular (across) to the flow.
Use the lowest available gear.
Dry brakes upon reaching other end by lightly stepping on brake pedal with left foot as you drive along.
September 13th, 2006 11:24 PM #47
If possible use the lowest gear. Do not step on the clutch. Do not rev too much, keep it between1,000-1,300 rpm, drive slow and as long as you are moving forward you're ok. High reving, especially on an engine mounted fan, would just scoop water into the engine bay spraying water into your distributor, coils and sparkplugs. An indication that that water is more than half a tire deep is the absence of a "thug, thug" sound in your flooring. It means the water has reached the underside of your car. Best to let a car pass and see how deep the water is. If in doubt, don't. My truck can ford waist deep water but unless it is really necessary I would think twice, coz taking out the carpet could be a real pain in the back. :D
September 14th, 2006 09:16 PM #48
-->>Ahh! thats why my dad long ago was too sLow when crossing a flooded street when i was little. even though the flood is just half-tire deep, ang bagal nya tumakbo,,heheh,,another knowledge learned.
di naman often na ngayayari yung katulad kay lady_guinevere pics Righhht??,, just a thought, can i seal the ECU,dipstick,hole in the transmision,etc and extended them to an higher location? plus improvise a hidden safari snorkel during rainy seasons?? hehejust a thought,feasible??
September 14th, 2006 09:24 PM #49
You cannot seal the ECU. The best you could do is know where it is located so you know how deep you can go.
On a Nissan Sentra the ECU sits on the hump on the floor before the center console so you'd need to have water up the handbrakes to fry it. On a gas-powered Pajero, the ECU is on behind the glovebox (high and dry), on most Isuzus the ECU is in the engine compartment (be careful), on a Fortuner it is under the driver's seat.
The dipstick is reasonably sealed (check if your dipstick has a gasket). And more often than not, the dipstick opening is about the level of the tires already. The breather can be extended using rubber hoses. Off-roaders have been doing it for years. For a manual transmission with the shifter directly entering the transmission body, there is really no practical way to seal that entry point.
Stock air intake systems will have safeguards against water ingestion. Just know where the intake draws air from (some draw beside the headlight, in the wheelwell, from the bumper etc.). At least you'll have an idea how deep the vehicle can go.
BANNED BANNED BANNED
- Sep 2015
- 13,917
July 17th, 2018 08:45 PM #50ano meron ba mga nabaha.
wag iistart sasakyan.
ipatow papunta trusted talyer
Agree on the consistent implementation of traffic rules and regulations. By privatizing MMDA,...
SC (temporarily) stops NCAP
