Results 31 to 40 of 60
FrankDrebin GuestSeptember 13th, 2006 08:58 AM #31
- Aug 2006
- 337
September 13th, 2006 10:16 AM #32
September 13th, 2006 10:31 AM #33
AFAIR, mataas ang breather ng transmission ng Kia Pride. That's a pretty sealed clutch housing para hindi pasukin ng tubig. Either that or the friction material in the Kia's clutch is not as sensitive to contamination.
September 13th, 2006 10:39 AM #34
Baka nabasa lang yun mga linkage na shifter going to the tranny. In a few days balik din sa dati yan. Just remember if your engine stalls do not, do not, try to restart it. Water could have entered your intake manifold and could be in you combustion chambers. As we all know water does not evaporates when ignited unlike gasoline. So imagine if water gets into your chamber, your engine stalls and you try to restart it, your piston goes TDC - say goodbye to your connecting rods.
Tsikot Member Rank 3
- Oct 2003
- 699
September 13th, 2006 11:02 AM #35
September 13th, 2006 11:21 AM #36
- Oct 2003
- 699
September 13th, 2006 06:00 PM #37pero di ba sa exhaust stroke ng 4-stroke engine, dapat nakabukas ang exhaust valve(s)? so, kung may water sa chamber, pagakyat ng piston sa exhaust stroke, di ba lalabas lang ito sa exhaust manifold via the exhaust valve? unless lunod na lunod ang combustion chamber ng tubig at hindi kayang lumabas lahat sa exhaust valve.
lastly, does water become almost solid in the combustion chamber? it can become solid at very cold temperatures and, at 4 deg celcius, actually expands in volume. pero at high temperatures (as in internal combustion engines), i would think mas malapit ito sa boiling point.
thanks again. like i said, dense ako sa mga ganitong technical stuff. also, hindi ako engineer so i wouldn't know about these things like the regular engineer. pasensya na sa kulit ko.
September 13th, 2006 06:04 PM #38
Try ko sumagot hehe
Compression stroke sarado lahat ng valves
Almost or virtually solid. Water is very difficult to compress. It's like falling into the sea from a 1000 ft height. Virtually same impact as when you fall on landLast edited by JohnM; September 13th, 2006 at 06:06 PM.
September 13th, 2006 06:04 PM #39
Water cannot exit the cylinder through the exhaust valve fast enough. And water can actually push the valve shut.
Due to the speed of the engine and general non-compressible state of water, the piston would feel like it just crashed into a concrete wall. Sort of like what happens when an airplane crashes at sea.
- Oct 2003
- 699
September 13th, 2006 06:07 PM #40
Ongoing problem pa din Pala ito even among euro cars ...
Takata Airbag Problems
