Page 15 of 66 FirstFirst ... 51112131415161718192565 ... LastLast
Results 281 to 300 of 1301
    #281
    Quote Originally Posted by edl100
    Hi, That is exactly what Rene said. High octane gas would have higher carbon build up sa EGR so using lower octane gas is better.
    What I will do is use high octane gas and just regularly clean the EGR, valve body and add some fuel injector cleaner occassionally.
    Yun lang nga, there will come a time na di na malilinis ang EGR and eventually masisira ito to the tune of P13,000!!!
    hi edl100. I guess the 93 octane suggestion will be ok kung mostly city driving. pero sa highway it makes a difference.
    baka you can post a how to clean the EGR and oxygen sensor. I saw elerick do it once, dapat pala nagpaturo ako
    Oct 2004
    #282
    Ma-rerepair yan. Try to go to Fronte in Banawe or call them up. Baka magawan ng paraan yan or baka makahanap sila ng parts coming from some korean car or van.
    I am sure mahal ang alternator na brand new..
    called up fronte, they said they dont repair electricals, mechanical specialty daw nila on the astra. thunder naman gave me a qoute of 44k for a brand-spankly-new alternator. buti na lang i reviewed kotiko's pm re mechanics recommended by elerick. sana hindi ic regulator sira or else its gonna be a 12.5k out of my xmas budget.
    kelan kaya next eb?
    Jul 2004
    #283
    Quote Originally Posted by natasatanas
    kelan kaya next eb?
    Hi, Ohh, di pala kaya sa Fronte? there is a guy there named boy electrician tapos di nila magawa??
    have you brought the alternator to a good car electrical shop?? Where did you bring it??
    Update us so kung masira ang alternator namin, we know what to do.
    Grabe!! P44,000!!
    Regarding the EB. lets set a date when we are all free. Last EB kasi, dalawa lang kami ni caloystermx5 ang nagpunta.
    Oct 2004
    #284
    may mechanic pupunta mamaya to check on my alternator. yoko i-byahe kc balak ko sa rey's electrical in 15th ave sa cubao. was there yesterday and had a chat with a guy there and told him about my problem, sabi nila they do opels too, at meron daw sila special tools. pero iba na yung may alam talaga sa opel, as in from the casa. will keep you guys posted for future referrence din po.
    boss edl100, kala ko nag push ka pa isang eb sa ortigas together with the new club you mentioned?
    #285
    natasatanas,
    pa share naman sino yung mga recommended mechanics ni elerick
    Oct 2004
    #286
    u have pm boss! cant post their names over the net.
    #287
    hi all.
    finally brought my car to fronte for the hub bearing replacement.
    arrived a little past 9 and i was their first customer for the day so mabilis naayos. mga 12 nakaalis na ako.
    I would've finished earlier pero ni recommend nung gumawa [his name is joey] na ipa reface ko yung brake discs kasi marami na canal. so they brought it to nearby machine shop. bumili din ng sandpaper para linisin yung brake pads. nilagyan nila ng canal yung brake pad para daw di na masyado maipit yung dumi which is causing the disc to be bad.
    caloystermx5, nakita ko si pecto!! kamukha talaga!!
    wheel hubs cost P9500 x 2 = P19,000, labor = P1,000, disc refacing x 2 = P1,200, sandpaper P20.
    am satisfied with the work. tsaka si jun ok kausap. would definitely go back there kahit medyo malayo from our house.
    help guys, meron na ba dito nagpa align? my car is pulling to the right. di ko alam kung sinong shop may specs for astra
    Oct 2005
    #288
    hahaha!! sabi sa yo kamukha!
    both your abs were busted? wow! buti na lang may fronte at thunder, layo ng presyo from the casa.
    i saw from another forum that cruven or zee ok daw pagdating sa suspension, di ko lang alam kung nag align sila. you can also try bridgestone sa fort, haven't had anything done by them pero mukhang ok yung place, they even have nitrogen for the tires (stable air temp in tire even at high speed daw).
    and you think you can send via pm the electricians of opel who do home service? natasatanas ok lang ba if i ask it from manager?
    Oct 2004
    #289
    Quote Originally Posted by caloystermx5
    yes naman po sir. ako pm para sayo na rin..
    Oct 2005
    #290
    kuha ko na, thanks!
    btw, yung boy electrician ng fronte is not an employee of theirs, he hangs around their shop and does jobs there (the extent of his electrician knowledge though am not sure as he just repaired my rear power window) so maybe that's the reason di sinabi ng fronte, but accdg to the people there magaling daw, fyi. siguro pag napadaan ka dun you can talk to him directly? just ask around, naka tayo usually yun dun, tambay hehe!
    Jul 2004
    #291
    Hi, Magaling nga sa rey's electrical. I used to bring in my Japanese cars there but I havent tried them too with the Opel electrical system. I guess naman pag defective alternator lang kaya na nila yon.
    I think it would be better to have a strict OPEL cars club. Hopefully we can organize something soon by next year??.
    #292
    only one hub was bad but i changed both sides na, usually kasi the other side will give up soon anyway.
    bridgestone is closest to me, and they said they have specs for astra. i'll go there soon.
    thanks again for the help
    Oct 2005
    #293
    Quote Originally Posted by manager
    no problem! feedback pls on the bridgestone tire center at the fort, thanks!
    Oct 2005
    #294
    btw, where is rey's electrical?
    and strict OPEL club sounds good! sana before year end eb-numan tayong unofficial opel clubbers, hehe
    Feb 2005
    #295
    Wow I can't believe there's a lot of us na! :D Way before I knew so few you owned one, and it was freaking hard to maintain. Ngayon kahit pano kaya na dumiskarte.
    Lets organize something soon! Dati pa gusto kaya lang di natutuloy. Lets continue to share tips and tricks!
    Oct 2004
    #296
    edit: oh sorry...double post!
    Quote Originally Posted by kotiko
    hello sir! kumusta ka na? tried wilson and pepe the other day re service of my alternator. how is your corsa doing? eb na!
    Oct 2004
    #297
    yep, i can vouch on this too..plus di sila tag sumingil at mababait kausap tao dun..natakot lang ako i-byahe astra ko kasi busted alternator, baka itirik ako.
    eb na sir!
    Oct 2004
    #298
    sir, rey's electrical is along 15th ave in cubao, nasa left side sila (rey villa). ako i take ermin garcia coming from tandang sora, then turn right na sa 15th ave since one-way, or else overshoot ka pag aurora blvd, unless you know the streets from aurora blvd to 15th ave.
    Feb 2005
    #299
    Hey guys member nga pala ba kayo ng AAP? Kung hindi, magmember na kayo :D Sobrang useful yung 24 hour free towing service nila :D
    Ayos naman yung Corsa, I'm happy na wala naman siyang sumpong lately. Although I've been noticing that the tambucho is kinda noisy and a slightly rattling. Anyone knows what could be the problem it has?
    Jul 2004
    #300
    Hi, to all the guys,
    What is the year model of your Opel and the Mileage??
    I feel ang taas na ng mileage ko for a 2001 model at 49,500kms. Daily driven na kasi since I sold my other car. I also think mahirap mag-benta ng car pag mataas ang mileage. Specially for an Opel, baka sobrang mura ko na mabenta and itago ko nalang yung car hanggang mabulok.
    What is a reasonable mileage for a used car??
Unofficial Opel Club! Calling all Opel Boys!
