For the first 2 years i had my astra i used unleaded and experienced the same problems you had. Especially morning starts the engine would waver between 500-1500 rpm!
Then i found out that the suggested octane rating for our engine is 95. so i switched to velocity and the problem disappeared. Since then its either velocity or xcs. I tried petron unleaded mga 3 months ago when my egr was cleaned and the ignition coil replaced because elerick suggested it. pero mahina talaga sya pag 93 octane. I also did a little research and seems to be the higher the ambient temperature, you should go for a higher octane fuel. i'm going to try 97 octane [blaze] this summer.
two weeks ago i discovered that seaoil regular unleaded is rated 95+ so i tried it. No problem! It even seems to have better performance
