Page 15 of 26 FirstFirst ... 511121314151617181925 ... LastLast
Results 281 to 300 of 505
    Jul 2013
    #281
    tanong ko lang about "warranty"
    so pagnagkaroon ng swirl mark within the warranty period, balik ko lang yung sasakyan?
    Dec 2017
    #282
    Thanks. Si misis kasi, sinabihan ng mga kapatid na magpa-ceramic daw...
    Matigil lang...
    May public transport ba from Optimum Impressions to Nuvali?
    Not sure about public transport. When I was there, Sir Donj offered to drive me to Solenad, but I opted to kill time sa Walter Mart instead.
    when I was in Optimum Impressions. meron white Everest na nag pa maintenance carwash. Walang swirl marks.
    we use c2v3 as a sacrificial layer so the CSL wont get swirl marks.
    the warranty is for product breakdown.
    Jul 2019
    #284
    mas maalikabok dito sa edsa bro lol. we're lucky the parking is covered. sa kabilang bahay sa edsa din. open parking. grabe ang fall out. kita talaga yun carbon sa black fort na waxed.
    1. covered parking if possible.
    btw even if you have your car coated. you still need to wash it. you just make it easiers for the car wash boys to wash it lol.
    2. as for coats. Im pro Gtechniq. its awesome value imo. 12k for 5yr warranty.
    1. Yes sir, balak ko ako na mag wash after magpa cocoat, magbibigay pala ng diy maintenance ung shshop para sa coating
    2. Salamat sir, mukhang go na ko sa coating hehe,
    Quote Originally Posted by onekind10 View Post
    if youll be doing the washes. a water filter is a good option if you want to avoid water marks. foam gun to reduce water usage. if youll do rinseless wash go Ultima WW.. I think the covers the basics.
    May 2017
    #286
    I use ONR as my rinseless/qd mix.. is the ultima ww way better?
    Sent from my SM-A600G using Tapatalk
    Oct 2018
    #287
    Quote Originally Posted by Shutterbug View Post
    Started with ONR, switched to UWW+. Mas madulas kasi UWW, kay mas confident ako when wiping the car.
    But according to Autogeek, both encapsulated irt to avoid swirl marks, pero mas kumpiyansa lang ako sa UWW+ dahil sa dulas. haha.
    As a tip, I use ONR with the rinseless wash dilution, and I mix car shampoo din to make it slippery.
    Apr 2012
    #288
    Quote Originally Posted by ironman06 View Post
    kung enough naman supply ng water, no substitute pa rin sa proper washing with water and shampoo. for me, marketing gimmick lang yung i-encapsulate yung dirt. gagasgas pa rin yung dirt sa paint once dumikit sa pamunas.
    Oct 2018
    #289
    Agree that a proper car wash is still the best. Pero kahit naman proper carwash na 2 bucket method, magkaka swirls and scratches parin.
    Whether rinseless wash or proper car wash, technique is the most important. If the car wash has the 2 bucket method, the rinseless wash has the Garry Dean method and its variations. Pero all of these only minimize the swirl marks, and reality is swirl marks will happen even to the best of us.
    I've washed my car with ONR ngayong may rationing, and after every wash i check for swirls sa hood. Being OC, mga 90 minutes ako nag lilinis using a rinseless wash. On a good day, no swirls pero pag minalas merong isa or dalawang bago. Pero I only do rinseless washes if light dust lang. If dirty/muddy, do a proper carwash parin.
    way better bro. i think everyone who tried both will attest to this and share this info.
    May 2017
    #291
    I just bought a gallon of ONR and you know how tipid these waterless solutions are... so i guess would have to wait for several years haha
    mas concentrated ang uww. 1gal of onr is easy to finish.
    Apr 2019
    #293
    Tnry ko uww sa hood. Di ko sure if gawa ko ung swirl marks haha. Pano nyo inaapply ung uww?
    Apr 2012
    #294
    Quote Originally Posted by chris45 View Post
    may mga vids sa you tube na pwede mo gayahin. you can spray both sa cleaning towel then sa panel. imo, para maging effective at maiwasan o minimize ang swirls, you need a lot of mf cleaning towels. hangga't maari one direction lang ang hagod then binabaliktad often yung towel sa fresh side kada hagod. if inuulit-ulit ihagod yung may nakadikit na dirt, yun mag cause ng swirls. if contaminated na yung lahat ng sides ng cleaning towel, discard mo na at gamit ka na naman ng malinis na towel. o di kaya, you can rinse and wring it saka ipagpag pero you might risk of having dirt pa na nakadikit.
    Oct 2003
    #295
    Magkakaroon talaga swirl marks kahit gaano ka kaingat. Pero ako I rarely do rinseless wash. Tinitiis ko talaga na umabot one week bago ako magwash.
    But if you have to do a rinseless wash talaga, gawa ka ng solution mo in a bucket and then in a spray bottle. Use the spray bottle as a pre-soak para basang basa na ung panel mo, even before wiping. I guess its better to use high gsm mf towels. Ganun din sa pag dry mo, high gsm mf towel.
    Apr 2019
    #296
    Kaya ata ngka swirl marks ay dahil nung dinetail ko na using clean towel back and forth pg punas ko then my dumi pa na dumikit sa clean towel. Dpt pala tnry ko muna sa side. Umaga kasi d halata swirl marks. Nung gabi na madami ilaw nakita ko dami swirl marks. Hays
    Mar 2017
    #297
    wala pa naman akong swirl marks from using UWW.
    yung routine ko is weekly UWW wash, tapos quarterly lang yung 2bucket car wash.
    scratches that I see are from my cats na nag ppa slide sa hood ko
    what I do:
    if light dust/dirt, spray on a panel, wipe the dirt in one swipe, switch sides of the MF towel tapos wipe uli sa ibang maduming part ng panel. (key is not to re-use the side which already picked up the dirt)
    pag nalinis na yung isang panel, buff lightly with another MF, tapos yung MF na yun yung next ko naman na ipang ppunas.
    makakadami ka talaga ng MF towel if you use waterless wash.
    (there are also youtube videos to explain this )
    pag medyo makapal yung dumi, same method pero soaked na din yung MF sa UWW.
    Nov 2011
    #298
    Ako naman tadtad na ng water marks dahil sa tag ulan. Visible pag may artificial light, pag sunlight hindi kita.
    Eto 5 mins na lang ako from garage umulan pa buset.
    Tiisin ko na lang not to dry it.
    Every weekend lang ako naglilinis kase.
    Apr 2019
    #299
    Quote Originally Posted by TheUninvited View Post
    With coating ya sir?
    Nov 2011
    #300
    Yep.
    Same thing happened today, pag kaalis ko ng bahay, umulan mga 2 mins then wala na.
    Pang asar masyado hahaha. hirap pag OC ka eh.
Ceramic coating
