Page 11 of 26 FirstFirst ... 78910111213141521 ... LastLast
Results 201 to 220 of 504
    Nov 2011
    #201
    Well after coating with TD, it got rained on after 14hrs.
    Hopefully it has cured already. Nilalagyan naman daw nila ng Reload pag maulan para sacrificial layer.
    Been a month now since, and I'm seeing less water beading already. I guess that's normal lang.
    Oct 2018
    #202
    Quote Originally Posted by chris45 View Post
    Pano mo nasabi sir na mas okay ang customer service and after-sales service ng TD sa ATMT?
    I never said TD's customer service and after-sales are better than ATMT. What i said was customer service and after-sales service are a selling point for me. There's a difference.
    Jun 2019
    #203
    is it really worth it?? damage around 18k...
    Apr 2012
    #204
    Quote Originally Posted by JEMANGALINDAN View Post
    worth it if its properly maintain. avoid run of the mill carwash shops that can ruin the coating. better still, learn proper washing and drying and DIY instead
    Jun 2019
    #205
    noted. thanks kuyang monty
    Oct 2003
    #206
    Quote Originally Posted by TheUninvited View Post
    What do you mean less water beading? Nag-po-pool ung water or sheets off? If it sheets off, thats better IMO.
    Does TD offer cquartz pro and finest?
    Nov 2011
    #207
    Quote Originally Posted by zechs View Post
    Pag tinapatan mo ng hose, mas mabilis mawala yung water dati compared to now. And yes, I'm seeing more sheeting than beading compared nung freshly coated.
    I think ATMT lang ang may Pro and Finest Reserve.
    how many years ang warranty ng TD? ang gusto ko ke Gtechniq 5yrs.
    Nov 2011
    #209
    I think 2 years, then maintenance after 1 year (free).
    But I'm planning to re-coat just after 1 year.
    It's really hard to tell kase if meron pang coating, unlike if wax/sealant, just reapply when in doubt.
    I think sulit naman yung yearly coating if 6x a week driven. Consolation lang na covered parking house/office plus pag weekend lang naarawan ng todo.
    Parang na-upgrade yung yearly detaling ko to yearly coating hehe.
    Oct 2003
    #210
    Depends siguro sa bagsak ng ulan or water kung mag bead or mag sheet. Pero sa akin din last step ko when washing the car is hose off lang with no pressure para mag sheet ung water pababa. Less effort in drying as compared to maraming water beads hehe
    Ako ung isang SUV, hindi ko pa na-re-recoat. I think mag 2 years na this year. Alaga lang ng nung Mckee's hydro blue spray and rinse off Si02 coating. Mga once in 3 months ko ginagawa.
    Madami na water spotting sa hood though (flat kasi, not angled). Planning to buy carpro essence plus, try ko kung matanggal. Hehe
    Mar 2019
    #211
    Whoa! A month pa lang after coating and the water sheets already with less water beading? Wow that is a bad sign.
    Oct 2018
    #212
    I had this issue initially. Paghugas ko sa car, it didnt bead and sheet. I contacted TD, tapos sabi niya, it wont talaga if the car is dirty. That time, naulanan yung kotse and nalagyang ng napakaraming dumi from the tree where it was parked.
    True enough after removing the dirt, it beaded and sheeted like it was supposed to do.
    So my tip is, if dirty talaga, remove the layer of dirt first. Yung dirt covers the coating below and is the one trapping the water.
    Quote Originally Posted by ironman06 View Post
    beading requires the surface to be clean. kinda weird lng na mawala agad yun beading lol
    Nov 2011
    #214
    Yeah, that was my assumption but it happens after hand washing and rinsing the car (not dried yet).
    I'll probably try to dry it first then hose it down again and try to check the beading.
    Mar 2019
    #215
    There you go. It was already clean but still no beading. Bottom line, the ceramic coating did not adhere properly to the clear coat after it was applied. I would blame that to the incident that the vehicle was exposed to rain even before the 24-hour curing time.
    Oct 2003
    #216
    As in no beading kahit na hose lang? Mukhang kailangan ulitin.
    Ung akin, one week di ko ginamit ung car after I coated it para fully cured na.
    Can you post pictures nung sinasabi mo *theuninvted? As in all panels ganun?
    Jun 2019
    #217
    1 week tlga po? any update naman po and kung sino gumawa? TIA
    Nov 2011
    #218
    I notice it lang sa mga panels that gets dirtiest the most - most noticeable sa lower part ng driver and passenger doors. Whilst the hood/roof and othe areas are still beading pretty good even if dirty (1 week no wash).
    I'll try to dry it then hose it down again. If it sheets, time to take it back to TD, I guess.
    Quote Originally Posted by Maria Salve View Post
    Try ko muna to dry by wiping and hose it down again. Tingin ko may car shampoo pa kase. That's probably masking the beading effect.
    I'll definitely post an update here.
    Oct 2003
    #219
    DIY lang ako sir. I bought my own chemicals from US
    *theuninvited,
    Cge check mo ulit. Pero sa akin kahit dirty ung lower panels (lower doors and bumpers), nagbe-bead pa din. And to early pa kung mag-decon wash ka ulit.
    Cquk 3.0 yan?
    Let me know if you want to try out my product hehe it boosts the coating properties bec of Si02 content.
    May 2007
    #220
    Personally, I prefer extensive water sheeting than beading. Yes, beading looks cool to watch but the main purpose of coating is to quickly repel water as much as possible to avoid watermarks and facilitate touch less drying. If water sheets quickly then I am assured that the coating is serving its main purpose of repelling water.
    Did TD conduct a "before" and "after" paint thickness measurement on random areas of your panels for your reference? If so, you can point out the areas where the coating failed due to significant variance in paint + coating thickness when you bring your car to TD for inspection. I assume TD applied the consumer grade CQuartz UK ver 3.0 to your car.
Ceramic coating
