Results 291 to 300 of 499
- May 2017
- 572
July 9th, 2019 06:19 PM #291
July 9th, 2019 06:42 PM #292
- Apr 2019
- 81
July 21st, 2019 03:40 PM #293
July 21st, 2019 03:58 PM #294
may mga vids sa you tube na pwede mo gayahin. you can spray both sa cleaning towel then sa panel. imo, para maging effective at maiwasan o minimize ang swirls, you need a lot of mf cleaning towels. hangga't maari one direction lang ang hagod then binabaliktad often yung towel sa fresh side kada hagod. if inuulit-ulit ihagod yung may nakadikit na dirt, yun mag cause ng swirls. if contaminated na yung lahat ng sides ng cleaning towel, discard mo na at gamit ka na naman ng malinis na towel. o di kaya, you can rinse and wring it saka ipagpag pero you might risk of having dirt pa na nakadikit.
July 21st, 2019 04:22 PM #295
Magkakaroon talaga swirl marks kahit gaano ka kaingat. Pero ako I rarely do rinseless wash. Tinitiis ko talaga na umabot one week bago ako magwash.
But if you have to do a rinseless wash talaga, gawa ka ng solution mo in a bucket and then in a spray bottle. Use the spray bottle as a pre-soak para basang basa na ung panel mo, even before wiping. I guess its better to use high gsm mf towels. Ganun din sa pag dry mo, high gsm mf towel.
- Apr 2019
- 81
July 21st, 2019 04:26 PM #296Kaya ata ngka swirl marks ay dahil nung dinetail ko na using clean towel back and forth pg punas ko then my dumi pa na dumikit sa clean towel. Dpt pala tnry ko muna sa side. Umaga kasi d halata swirl marks. Nung gabi na madami ilaw nakita ko dami swirl marks. Hays
- Mar 2017
- 141
July 22nd, 2019 03:05 PM #297wala pa naman akong swirl marks from using UWW.
yung routine ko is weekly UWW wash, tapos quarterly lang yung 2bucket car wash.
scratches that I see are from my cats na nag ppa slide sa hood ko
what I do:
if light dust/dirt, spray on a panel, wipe the dirt in one swipe, switch sides of the MF towel tapos wipe uli sa ibang maduming part ng panel. (key is not to re-use the side which already picked up the dirt)
pag nalinis na yung isang panel, buff lightly with another MF, tapos yung MF na yun yung next ko naman na ipang ppunas.
makakadami ka talaga ng MF towel if you use waterless wash.
(there are also youtube videos to explain this )
pag medyo makapal yung dumi, same method pero soaked na din yung MF sa UWW.
July 22nd, 2019 11:17 PM #298
Ako naman tadtad na ng water marks dahil sa tag ulan. Visible pag may artificial light, pag sunlight hindi kita.
Eto 5 mins na lang ako from garage umulan pa buset.
Tiisin ko na lang not to dry it.
Every weekend lang ako naglilinis kase.
- Apr 2019
- 81
July 24th, 2019 02:05 AM #300
2024 Honda City V with Honda Sensing: 5 Things we like | Top Gear Philippines Top Gear Philippines
2020 Honda City
