tanong ko lang about "warranty"
so pagnagkaroon ng swirl mark within the warranty period, balik ko lang yung sasakyan?
Started with ONR, switched to UWW+. Mas madulas kasi UWW, kay mas confident ako when wiping the car.
But according to Autogeek, both encapsulated irt to avoid swirl marks, pero mas kumpiyansa lang ako sa UWW+ dahil sa dulas. haha.
As a tip, I use ONR with the rinseless wash dilution, and I mix car shampoo din to make it slippery.
Agree that a proper car wash is still the best. Pero kahit naman proper carwash na 2 bucket method, magkaka swirls and scratches parin.
Whether rinseless wash or proper car wash, technique is the most important. If the car wash has the 2 bucket method, the rinseless wash has the Garry Dean method and its variations. Pero all of these only minimize the swirl marks, and reality is swirl marks will happen even to the best of us.
I've washed my car with ONR ngayong may rationing, and after every wash i check for swirls sa hood. Being OC, mga 90 minutes ako nag lilinis using a rinseless wash. On a good day, no swirls pero pag minalas merong isa or dalawang bago. Pero I only do rinseless washes if light dust lang. If dirty/muddy, do a proper carwash parin.
may mga vids sa you tube na pwede mo gayahin. you can spray both sa cleaning towel then sa panel. imo, para maging effective at maiwasan o minimize ang swirls, you need a lot of mf cleaning towels. hangga't maari one direction lang ang hagod then binabaliktad often yung towel sa fresh side kada hagod. if inuulit-ulit ihagod yung may nakadikit na dirt, yun mag cause ng swirls. if contaminated na yung lahat ng sides ng cleaning towel, discard mo na at gamit ka na naman ng malinis na towel. o di kaya, you can rinse and wring it saka ipagpag pero you might risk of having dirt pa na nakadikit.
Magkakaroon talaga swirl marks kahit gaano ka kaingat. Pero ako I rarely do rinseless wash. Tinitiis ko talaga na umabot one week bago ako magwash.
But if you have to do a rinseless wash talaga, gawa ka ng solution mo in a bucket and then in a spray bottle. Use the spray bottle as a pre-soak para basang basa na ung panel mo, even before wiping. I guess its better to use high gsm mf towels. Ganun din sa pag dry mo, high gsm mf towel.
Kaya ata ngka swirl marks ay dahil nung dinetail ko na using clean towel back and forth pg punas ko then my dumi pa na dumikit sa clean towel. Dpt pala tnry ko muna sa side. Umaga kasi d halata swirl marks. Nung gabi na madami ilaw nakita ko dami swirl marks. Hays
wala pa naman akong swirl marks from using UWW.
yung routine ko is weekly UWW wash, tapos quarterly lang yung 2bucket car wash.
scratches that I see are from my cats na nag ppa slide sa hood ko
what I do:
if light dust/dirt, spray on a panel, wipe the dirt in one swipe, switch sides of the MF towel tapos wipe uli sa ibang maduming part ng panel. (key is not to re-use the side which already picked up the dirt)
pag nalinis na yung isang panel, buff lightly with another MF, tapos yung MF na yun yung next ko naman na ipang ppunas.
makakadami ka talaga ng MF towel if you use waterless wash.
(there are also youtube videos to explain this)
pag medyo makapal yung dumi, same method pero soaked na din yung MF sa UWW.
Ako naman tadtad na ng water marks dahil sa tag ulan. Visible pag may artificial light, pag sunlight hindi kita.
Eto 5 mins na lang ako from garage umulan pa buset.
Tiisin ko na lang not to dry it.
Every weekend lang ako naglilinis kase.
