Page 377 of 422 FirstFirst ... 277327367373374375376377378379380381387 ... LastLast
Results 3,761 to 3,770 of 4217
    #3761
    Kung yung eg hatch has a PH12 or D13/D15 stock engine (not modified) kayang sibakin yan ni 1ZR-FE [emoji16]
    Ibang usapan na iyan pag naka b series or k series yung eg civic. Hahahah
    Sent from my SM-N970F using Tsikot Forums mobile app
    Noone races with a PH12. Usually D15. And a D15 has 130 hp with a 950 kg body. But more than outright power, cornering ability wins races - which is why good tires, suspension, and brakes are far more important than horsepower.
    #3762
    NA engines pa lang usapan dito. Ano pa kung turbocharged engines?
    You know what would be a good Honda project - A Jazz GE (2nd gen) with an L15B7 (Civic RS). Comfy enough for a daily drive but it would be crazy quick.
    #3763
    that would be nice to see contrast sa K20A swapped Jazzes. we know the k20 has more power pero baka torquier down low ang l15 turbo.
    #3764
    May kumakarera sa Touge Battle with a GD Jazz with L15 turbo.
    Tuned all-motor B16/B18/B20 Civics are still faster.
    #3765
    sorry ot lang ng konti.
    question lang kasi medyo lito ako na skip ko ata yung phase ko na pagiging honda fan boy nung 90's hehe. medyo matanda na kasi.
    ang Ph16 ay chassis code tama ba po ng mga VTI?
    D16y yun single VTEC engine ng VTI?
    tapos yun local na LXI is a D15 single VTEC engine as opposed to D15B double VTEC na Japan with P08 computer box version?
    tama po ba?
    #3766
    The usual NA K20 A3/A4 (Accord 7th gen, Civic FD, CRV 2nd gen) is only rated at less than 160hp/188Nm while the most powerful one, K20A, is rated at around 220hp/200Nm which was used on the Integra and previous Civic Type R.
    The L15B7 in its lowest output tune (Civic RS) is rated at 174hp/220Nm while the most powerful version is on the Civic Si rated at 205hp/260Nm.
    The new Civic Type R uses a turbo version of the K20, the K20C. It is rated at 306hp/400Nm.
    #3767
    i have not seen an non "A" K20 swapped into a jazz. but in any event 160hp is still significant for a jazz
    #3768
    Yung sayang talaga is the Mitsu Evo. They even came up with the bonkers FQ400 model which made 400hp/500Nm from its 2.0L engine.
    #3769
    ^ kaya ba kumana ang all -stock fd2 na a/t sa mga ganito?
    #3770
    The Civic FD 2.0L had a K20 engine rated at over 150hp. It is quick and fast for a stock compact car but against the new turbo Civic RS or Mazda3 2.0L, it will be challenged. Against tuned Civic EKs or a WRX STi or Evolution with around 300hp, it will be no contest.
"BADUY" car thread
