Page 582 of 729 FirstFirst ... 482532572578579580581582583584585586592632682 ... LastLast
Results 11,621 to 11,640 of 14580
    Jan 2008
    #11621
    Quote Originally Posted by patapotatoe View Post
    Good day to all BOSBs. I went to Subic 2 weeks ago and when I came back there was a sudden decrease in power in my Strada. Whenever I released the gas pedal the car would jerk wildly and kahit na 4000 rpm na bitin pa rin sa hatak. The following day I brought the unit to Mitsubishi-Valle Verde and they told me that there was a problem with the suction control valve. Until now, they haven't finished fixing my unit. I called again this afternoon and they said that there was another problem with the air flow sensor. I don't know what's taking them so long to fix the problem and on top of that the service/updates are really terrible. Kung di pa ako tatawag di pa nila sasabihin kung ano yung problema. Have any of you experience the same problem with the SCV + air flow sensor? and if you did how long did it take for you to have your unit fixed? Thanks in advance.
    Sir, nung nagloko SCV ng Strada ko, yung loss of power kasabay eh drop ng rpm. Pero sa iyo, umaakyat pa ng 4000rpm tapos wala hatak. This could be due to another problem. Alam ko may nagkaproblema sa hose clamp, di kaya eto problem. Or dirty air flow sensor?
    Baka kaya natatagalan kasi walang available parts. I remember yung sa kin, the casa ordered the SCV and it took 2-3weeks before it arrived. Same with the steering column.
    Jan 2008
    #11622
    Quote Originally Posted by nanofossil View Post
    doc boz, ganda ng mga shots mo, hehehe iniisip ko lang kung ano ang posisyon mo habang kumukuha ka ng shots.
    Di naman sir nano, point&shoot lang yan kaya kaya ko i-position kahit ano angle. No need to look at the LCD. Tantyahan lang.
    Quote Originally Posted by arsen View Post
    Pwede po bang pa post ng side view ng leaf spring assembly pati yung shackle?
    Gusto ko lang makita ang side view ng dulo ng 2nd, 3rd and 4th leaf (hanggang sa may rebound clip).
    Pati na rin ang shackle (rear bracket assembly na kinakabitan ng leaf spring) kung meron ba syang grease nipple.
    Yun na lang po muna... pa post na lang ng additional photos...
    Try ko sir. Pero mas mahirap na angle yan. Hehe. Dapat tanggal wheel/tire. Again, I've narrowed down/pinpointed the source of the squeak sa 2ng U bolt/wrap by trial & error.
    Quote Originally Posted by Arvin Cristi View Post
    boz, bili ka na ng bagong shocks!!!
    Medyo malaki kailangan budget dyan, sir arvin. Kasabay nyan lift kit +/- bigger tire/wheel combo. Hehe. Kayaba na lang kaya muna?
    #11623
    thanks a lot sa info mga sir! bukas na bukas bibili po ako ng wd40.
    Dec 2009
    #11624
    i think the driver's factor play, depend on how he start and how fast his shifting on gear and how he rev up.
    Dec 2009
    #11625
    you are right there. but i think that's not u-bolt. just spray wd40 on that particular area. applying grease is not advisable cz it damage the rubber insulation. any petroleum can damage rubber.
    Dec 2009
    #11626
    i think they have to check your electrical system either there's a grounded causing to failure of your sensor. maybe later even your module might be affected. if not, your module have problem.
    #11627
    all the problems and complaints that i've been reading lately in this forum is starting to get me worried, to think that the strada is already in the middle of its life cycle since it was released in 06, then they have come out with a facelift and yet the problems still come up.... i hope the people who poststheir problems are just a smallpercentage of the total strada users out there.
    Dec 2009
    #11628
    Quote Originally Posted by KCboy View Post
    mga strada gurus,
    the easy select 4wd system of the strada, is it the same as the super selct of the pajero where in you can shift to 4H even on paved roads or is it only for rough and unpaved roads??? i know the easy select is shift on the fly upto 80 to 100kph, the question is whether it is on paved roads or rough loose surfaces???
    i think you're unit is matic, it does not mean that you can engage your front drive on pavement. it might damage your front differential cause we are part time 4x4. not full time like outlander system or all wheel drive
    Jun 2008
    #11629
    Quote Originally Posted by blue ice View Post
    sir just my side the 4H can be engage in pavement and rough road basta nasa allowed speed ka, using 4h in high ways for part time have a speed limit i use it kung bniglang umulan nag malakas to give me more control of my truck, all information on how to use the 4H and 4L is in the manual.
    Sep 2004
    #11630
    the noisy leafsprings are the most problematic on the strada..not a safety factor but a noise pollutant. but the noise is not such a big deal, but still a problem. i am glad i dont have that.
    Dec 2009
    #11631
    Quote Originally Posted by dadz View Post
    Copy sir. option on case to case basis like flooded area and strong current.
    Dec 2009
    #11632
    [quote=RTS;1376172]Kerosine- a foe or friend ??
    I've been in petroleum transportation for quite sometime(exxon)and it is acceptable to mix small amount of kerosine to diesel, in fact will improve the octane of the diesel. Im not asking you to do this but it is my practice to every full tank of diesel I topped off(70ltrs) I mixed 1 & half ltr of kerosine to imroved the ignition properties, This is my 3rd gen pick up & Im doing these eversince . These was not my idea but suggested by petroleum engrs. provided that you stay w/in the proportion. Jets are using kerosine(layman term) as their fuel , we used to called it turbo jet or JP1 fuel, only it passed higher standard of filtering process & moist removal plus anti static additives.For your peace of mind you can ask the Techinical expert of MITSU .
    Copy sir. Are you sure we need to improve the octane rating on our diesel fuel? I thought diesel fuel is rate by cetane. Is it applicable to the crdi engine?
    #11633
    thank you for the information, i just wanted to be sure because when i asked the SA, he wasn't sure either. im familiar with the 4wd system of mitsubishi, i was just curious and made me doubtful because it used to be called super select and now they use easy select. thank you for the clarification. i also want to note thatthe montero spost's 4wd system blinks first when you engage it,same for the gen2 and gen 3 pajeros, while on the strada, no more blinking, the 4wd just lights when you engage it.
    Mar 2004
    #11634
    Most new 4WD systems can be used on paved roads when set to 4H.
    #11635
    not necessarily true, i believe it is only the strada( for the pick up market in the philippines), is the only pickup that has a shift on the fly 4h that can be used for highway driving; the rest of the bunch, are for unpaved rough roads only. hail to the strada.
    Jun 2007
    #11636
    Quote Originally Posted by RTS View Post
    RTS
    sir...If I may ask...whats your unit? is it a 3.2 or 2.5? TIA
    Jun 2009
    #11637
    mine is 3.2 A/T, since June 09
    RTS
    Jun 2007
    #11638
    sorry to hear that bro.....
    I sure hope that its all covered by the warranty....
    please do update us on it...
    and lets wait for the others who have already experienced it....
    Jun 2007
    #11639
    Just to concur on this one...
    when I was in the dealership having my ride detailed.....I happen to have a chat with 2 thundercat brothers....who just had their 3 day old strada being detailed also...and they said that they were able to run on 4H til 120Kph....
    kas may nanghiram daw na tinesting yung 4x4 tapos nung ibalik sakanila inde naka 2H tinanong ko kung may naging problem....wala naman daw problema except for the consumption...which is expected naman...hehe
    Im just not sure about the other pickups in the market on being it not able to engage 4x4 on pavement.....But IMO I think pwede din siguro sila kasi puro indash na di pihit na yung 4x4 nila and inde na kambyo which I think more appropriate on onroad application.... Im not sure though...anybody can coonfirm?
    Jun 2007
    #11640
    RTS
    so how was it? since the day you started adding the kerosene?
    any changes in performance or anything like lesser noise production?
