Page 86 of 470 FirstFirst ... 367682838485868788899096136186 ... LastLast
Results 1,701 to 1,720 of 9388
    #1701
    any GLS Sport owners here able to add the rear fog from the GLS Sport SE? kailangan ba palitan ang stalk switch? wala pa abang na linya?
    also, has anybody noticed if the cargo area cover is already available and how much?
    thanks
    #1702
    hi guys, my SA delivered my MS 4x2 today sa bahay, red sya. wanted to share some pics sana, kaya lang i dont know how to attach here. anyway, i'm very pleased with my MS and i must say that its worth every cent.
    question lang po,
    1. is it true that i cannot run my MS more than 100km/hr if it has not yet reached its first 1,000km? and completed its first pm?
    2. what type of oil do i need to use for my first 1,000km pm? i was told that i should not use synthetic oil.
    3. what are the do's and dont's during the break-in period? what do i need to look out for?
    pasensya na po sa mga questions na 'to, this is my first brand new vehicle kasi.
    thanks in advance..
    best regards,
    howie
    May 2007
    #1703
    Quote Originally Posted by Howie View Post
    question lang po,
    thanks in advance..
    best regards,
    howie
    sir howie, congrats po for your new purchase! im sure the monty will work fine for you.
    pls. click on the link for posting pictures:
    http://tsikot.yehey.com/forums/showp...ostcount=11553
    to answer your questions: --AFAIK (as far as i know)--
    according to the manual, it is ideal to maintain speeds below 100kph for the break in period. however, some MS owners here did otherwise and (i think) they haven't reported any problems after doing so. feel free to back read about 20-35 pages of this thread to find out po. You can also refer to the owner's manual for other Do's and Don'ts for the break-in period and PMS details.
    pls. click on the link for the Montero Sport PMS thread:
    http://tsikot.yehey.com/forums/showthread.php?t=56817
    i hope this helps... thanks.
    May 2007
    #1704
    Quote Originally Posted by dexlab View Post
    thanks
    what i'm sure about is with the stalk- pareho for all the Montero Sport Line-up (take note: 2.5 GLS 4x2, 3.2 GLS 4x4 and 3.2 GLS SE 4x4) pati sa Strada! if you can look closely at the ring to twist upward and downward, there are two arrowheads. twist it upward once will turn on the front foglamp and the second time will turn on the second foglamp. this is vice versa with turning it off by twisting it downwards.
    as far as the wiring goes, i will let the monty owners answer that... some of them might have gone to the bone to check the wirings... hehehe... thanks
    tonneau cover you mean? so far wala pa yata. this feature is very useful with my Space Wagon and im sure its useful for the Outie Users as well.
    #1705
    Quote Originally Posted by ZEUS75 View Post
    1k pms ng monty ko:
    Kar asia davao
    9liters motor oil xp (553.57) p4,982.13
    1pc oil filter 2,142.84
    total 7,124.97
    vat 855.03
    p7980.00
    1000km pms check up p399.00
    car care kit application 250.00
    spray degreaser 150.00
    799.00
    discount (free labor) (399.00)
    400.00
    [size=6]total cost [/size][size=7]p 8,380.00[/size]
    Same price I paid for the 1k PMS at Kar Asia. However, hanggang change oil (synthetic) and filter lang. I noticed higher ang price ng oil and oil filter. Makes me think about supplying my own oil (I can get higher/better specs than the xp turbo) and also get the orig oil filters in Mitsu Casas in Manila.
    Can someone advice me ano ang high, low and fog lamp types (h3, h4, h11, etc) ng MS? I read it somewhere in this thread pero hindi ko na mahanap. I dont have access to my owner's manual as I am out of town and planning to buy some HID lamps. Plano ko HID for high beam and fog lang kasi I find it weak when you turn it on sa dark and hilly roads going to and from gensan.
    Thanks in advance
    Rangered
    Dec 2008
    #1706
    Quote Originally Posted by mantisxxx View Post
    mukhang ito na nga sir... i drop na nga daw po yung 4x4 GLS na variant tapos 4x2 ang ipapalit ... sana dinagdagan pa accesories ...
    ok lang naman kung magkakamukha mga units natin eh.. sa gls se, yung "SE" and yung sa left na rear light lang naman ang difference eh compared sa gls.. yung sa 4x2 and 4x4, if it's really identical sa exterior, ok lang din yun i guess
    It's better to have a montero with similar looking variants than not have a montero at all
    Aug 2008
    #1707
    tsk tsk. and people thought getting a diesel suv is always cheaper in the long run. i had a santa fe for 2 years now, my first crdi. pero pag-kinompute ko talaga cost ng PMS vs. a 3rd gen CRV ng cousin ko. talagang i'm going to pay more.
    anyway, hindi kayo nag-iisa. malamang mga naka-fortuner na diesel ganyan din inuubos.
    1k pms ng monty ko:
    Kar asia davao
    total 7,124.97
    vat 855.03
    p7980.00
    799.00
    400.00
    [SIZE=6]total cost [/SIZE][SIZE=7]p 8,380.00
    [/SIZE]
    [SIZE=7][/SIZE]
    [SIZE=7] [/SIZE]
    Nov 2007
    #1708
    Quote Originally Posted by rangered View Post
    Thanks in advance
    Rangered
    Kompletuhin ko na, ayon sa manual:
    Outside
    Front
    1. Headlamps, high beam: 60W (HB3)
    2. Headlamps, low beam: 55W (H11)
    3. Position lamps: 5W (W5W)
    4. Front turn-signal lamps: 21W (PY21W)
    5. Side turn-signal lamps: 5W (WY5W)
    6. Front fog lamps: 55W (h11)
    Rear
    7. High-mounted stop lamp: 16W (W16W)
    8. Tail and stop lamps: 21/5W (P21/5W)
    9. Rear turn-signal lamps: 21W (P21W)
    10. Tail lamps: 5W (W5W)
    11. License plate lamps: 5W (W5W)
    12. Rear fog lamp (Driver's side): 21W (P12W)
    Reversing lamp: 21W (P21W)
    Codes in parentheses indicate bulb types.
    Inside
    1. Door courtesy lamps: 3.4W
    2. Front room lamp and personal lamps: 7.5W
    3. Center console down light: 1.4W
    4. Glove box lamp: 1.4W
    5. Rear room lamp: 8W
    6. Luggage compartment lamp: 8W
    #1709
    Hi Outcast,
    Thanks for the info. I'm thinking of putting 4300k for hi beam as it gives better visibility at night, raining or foggy conditions. Had used superwhite halogens before and it really do not fit into those driving conditions. Any comments or suggestions?
    TIA
    Rangered
    Quote Originally Posted by Outcast View Post
    Outside
    Front
    Rear
    Inside
    #1710
    mga sir, question po... meron na po bang nakapaglagay ng LCD HU sa montero? kung meron po pa post naman po pics or maski na link na lang...
    salamat po
    Oct 2008
    #1711
    Hi Outcast,
    TIA
    Rangered
    Hi, in my opinion if you want the best and brightest shade of HID for any driving condition, it would be the yellow ones, 3000k. Definitely it'll be bright as crazy! Another advice is.. don't get cheap HIDs if you want it for function. A lot of people buy the cheaper HIDs thinking its all the same.. YOU ARE WRONG! (to those with cheap HIDs thinking its the same). If you're like me and want it both for the looks but mainly for its function, check out the philips HIDs and also the 50watt HID from Xenon bulbs. THose are very very bright even if you get the white ones, 6000k color. But i think for functionality and brightness alone, the 3000k would have to be the best for all road conditions.
    I'm currently using 50watt 6000k HIDs from xenon-bulb.. and i can outshine and even brighten up the road for the people around me.. I'll definitely eat the brightness of the cheap HIDs even if i'm behind them, my beam will go further than theirs. There's a story behind that too, but that's for next time.
    Hey i'm sorry for those who are affected.. I have nothing against you personally, just your lights. Again, its just a personal opinion/preference and i'm not out to specifically or directly insult anybody.
    salamat po
    LCD HU? That's the same as a DVD HU right? or is that a new tech i've haven't heard of yet? Or i'm just so sleepy i can't think straight?
    Well if its a DVD HU, or a monitor, check back in the earlier posts.. i posted some pics of my HU and where i placed it. Check along the pages in the 50s or 60s. i think its there somewhere.
    #1712
    Quote Originally Posted by kkkkkl View Post
    mga boss, pano kapag pinara ka ng pulis kasi wala pang plaka ung car mo tapos yung napakita mong resibo e lagpas na ng 7 days anong gagawin nya at anong dapat kong gawin? SALAMAT
    the trick there is that the CASA will give you 3 letters of certification, 1 for each week, certifying that the plate is being processed, that's how my casa did it, and they did what they said, before the 3rd letter expired, i got my plate number already complete with OR and CR. so that way, you can still use your MS as often as you want, but just be careful, i am afaraid pretty soon, the MS will be the target of carnappers since it is the hottest selling suv now in the philippines.
    #1713
    Quote Originally Posted by beaumec2000 View Post
    Union Motors Paco sucked big time. I was referred to them coz they have remaining white units of the GLS variant. I thereupon reserved one and had my bank send them a P.O. pronto. A few days later as I was paying the D/P, they told me that they were not releasing the unit to me coz my financing was not coursed through their in-house financing. Bottomline, since there are only a few GLS units left in the market (having been phased out with the entry of the 4x2 2.5 L variant), they are going to sell them only to those who will avail of their atrociously high in-house financing rates (around 10% rate difference for a 60 month term). *#^*/=! I had to settle for a silver GLS which I got from a provincial dealer. Getting a GLS SE is not an option as I have a driver and he is the only one who will get to enjoy the power adjustable driver seat.
    They will surely not be getting any business from me in this lifetime.
    got the same experience too from that CASA, the manager was a real A#*HOLE but as i was leaving the showroom, the SA felt bad and refered me to another casa in bulacan, got my unit the same day. wish their sales were as good as their service department.
    #1714
    Quote Originally Posted by N T Y c E View Post
    Thanx JPG111 for the help with the pic.
    sir N T Y c E, salamat po. I was referring to any HU na may LCD (whether monitor lang sya or with player na din. )
    Nga pala sir, I noticed nga pala na iba na yung shape ng center dash ny. I compared it dun sa brochure ng GLS SE. May binutas po ba kayo sa center dash para magkasya yung jvc monitor/player nyo or pinalitan nyo buo yung pinaglagyan nya?
    medyo iba din po kasi sa 4x2 kasi may lid na sya and di ko maisip kung pano ilalagay dun yung HU na may LCD.
    salamat po uli
    #1715
    good day, I've read here that on a typical change oil of the montero 3.2L A/T uses 9litres of engine oil. Its a lot, is this 9litres also used to lubricate the transmission system? some 2.5l diesel M/T of other manufacturers require only 4.5 litres of oil. just curious
    #1716
    howdy guys, just placed a reservation for a white 4x2 last thursday, still waiting for the unit. One question lang, will there be a m/t variant of the montero sport? good day
    Sep 2004
    #1717
    I am extending The Strada Club (TSCP) joint meet-up with Club Mazda3 on March 28, 3pm Metrowalk gravel Parking. You may use this time and venue to meet fellow MS owners as well as your friends from Strada Club and Club Mazda3.
    I know many interested MS owners would like to start your own club, and a few have started to initiate the meet but did not push through for whatever reason. Even if only less than 5 would be available, at least you would have started the ball rolling.
    Hope to see you guys there. Nothing formal, just a gathering of Mitsu and Mazda enthusiast. I have also extended invites to Club Outlander of the Philippines (COPS).
    Congrats to the new owners of the MS. Now you know why TSCP have been active and been vocal about this vehicle, now you MS owners are also feeling that excitement with your Montero Sport.
    Sorry for the O.T.
    Oct 2008
    #1718
    salamat po uli
    Where my HU is now, use to be a display and console slot, (anybody have a pic to help explain?). I yanked it out and replaced it with the HU. It directly fits, because originally, that area is meant for gps monitors or 2din monitors. So its really meant for a 2din HU. The tricky part is choosing the right HU because its kinda shallow since the a/c duct is exactly behind it, that's why mine is kinda poping out, but very minor. And if you look towards the bottom, under the a/c controls, there's a compartment there? That use to be where the stock HU was installed. I think i remember seeing a pic of the 4x2 and display on top is something else or is different?
    So any good installer should be able to put any 2din HU in there, maybe slight shaving to fit, depending on HU, but i think it should fit most 2din HUs no problem. I can't remember the 4x2s console but i noticed it was different nga from the 4x4, but i'm sure you can take that out also and replace it.. if you don't mind taking it out and voiding few warranties. hehehe
    Jun 2005
    #1719
    sir what did you do with your multi-info display?
    Sep 2004
    #1720
    your exactly correct on your statement. the 4x2 console would be like its sibling strada glx with a cover that can be lifted to open up that space. you can take out that as it is one piece and put in a 2din HU.
