Results 1 to 10 of 123
December 18th, 2013 10:59 AM #1
Any recommendations on where can we have the timing belt replaced at the least cost? Thanks.
- Sep 2011
- 626
December 18th, 2013 11:52 AM #2^Up. Im nearing 60K already.
At what km reading are you now sir?
The manual recommends to change it between 60k to 80k. Kung ok pa siya once magpa change oil ako, baka sa 70K nalang ako magpalit.
Mukang marami rin atang tatangalin kasi medyo masikip yung engine space.
December 18th, 2013 12:27 PM #3
- Sep 2011
- 626
December 18th, 2013 01:26 PM #4Sobra naman. Magkano lang naman belt.
20K for timing belt replacement? pass haha.
How about on your suking gas station sir? Here on our place, may gas station dito na maraming nagpapagawa e.
Kanina lang nagpagas ako dun, roughly nasa 20 cars nagpapagawa. Hindi na kasya sa service bay.
Much better din kung sa acredited mitsu store din bumili instead sa casa.
Paging sir Zix...
December 18th, 2013 03:58 PM #6
actually mga sirs hindi lang yun belt ang papalitan. ang pricey is yun mga bearings. pati oil seals need palitan since open na din nman. mga ilang parts din yun pero medyo may kamahalan talaga yun 24k...
- Sep 2011
- 626
December 18th, 2013 04:24 PM #7
December 18th, 2013 04:25 PM #8
December 18th, 2013 06:38 PM #9
Mga Sirs,
I need your expert thoughts. I just read the 2 Service Booklets that came with our Montys. The Thailand Service Booklet (Blue) recommends timing belt replacement every 80,000-100,000 kms. (nakagisnan natin na standard). The Philippine Service Booklet (Green) naman recommends replacement by 60,000-80,000 kms. Sino sa kanila nagsasabi ng totoo? Galing Thailand lahat ng Montero sa Pinas. Gusto lang bang "kumita" ng Mitsubishi Phils?Last edited by roydok; December 18th, 2013 at 06:45 PM.
December 19th, 2013 03:28 AM #10
Not on a mitsu but they are an suv specialist shop so I had dr. G in q.c. Do the tbelt change on my old toyota. Labor was a little under 6k. Replaced the belt, water pump, thermostat, tensioner, fanbelts, all fluids and filters.
I just bought my own parts as per shop advice. Mostly original except for the tensioner bearing which was koyo (original was also koyo) and the water pump with aisin (they also make the orig water pump).
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
