Page 123 of 162 FirstFirst ... 2373113119120121122123124125126127133 ... LastLast
Results 2,441 to 2,460 of 3240
    #2441
    Oh!ang laki deperensya sir!thank you so much sa info..i will visit soon for my 80k pms.work performance is it ok?
    #2442
    Sir can you tell me the exact place of FDS auto?sori im not familiar the kamagong and springdale.is it in mandaue or cebu city.
    Aug 2003
    #2443
    Bai. Its best to check it on google map. Type paref springdale school, its address shows gorordo ave but when you check google map, it will show its on kamagong. From google map, it will show kamagong turn, but there is an alley that is a dead end. You need to go to this alley. There is a nearby shop when kamagong turns, you might mistake this as frederick's shop.
    Ok ang trabaho. He is the one who cleaned my monty's inhibitor switch that casa will only replace. Same with other shops i asked in manila and cebu. I like shops that know how to find solutions other than just replace.
    Dec 2014
    #2444
    EGR Cleaning c/o Zix
    BEFORE
    AFTER
    Jun 2007
    #2445
    Sir ask ko lng po hm?
    #2446
    Thank you sir...
    Aug 2004
    #2447
    Montero 2012 gls-v.. umilaw yung CEL kahapon habang nasa byahe ako, nasa 38k+ na odometer. i suspect na fuel filter ang culprit kasi umilaw din yun last year around June (mileage is 18k+) then fuel filter din ang pinalitan ng casa.
    dinala ko sa casa ngayon pero sarado pala kc holiday. dumaan ako sa auto supply and nagtanong kung may OEM sila, wala daw & ang nirecommend nila is VIC * 650 daw..
    pwede na ba yun pamalit instead of OEM. may byahe kc ako bukas ng umaga kaya need na palitan today. automatic ba na mawawala yung CEL kapag napalitan yun?
    Sali mo na sa SUA phenomenon yan! [emoji16]
    Jul 2003
    #2449
    pwde mo palitan lang to Vic at gamitin mo maybe 1000 kms then for peace of mind palitan mo OEM from casa later.
    so far ang nababasa ko dito sa forum, best to replace fuel filter as early as 10,000 kms vs 20,000 kms. sa mura ng replacement brand e kahit 5000kms afford.
    sa local gas station ako nag papalit ng vic fc-135, 350 filter 150 kabit. nag palit ako at around 16,000kms usage ng OEM filter. feel ko lang may tubig/madumi kaya palit during the weeks before and after lando.
    about sa CEL reset, dont know.
    Quote Originally Posted by Elroi View Post
    Aug 2004
    #2450
    hehe.. tingnan ko muna kung ano mangyari dun sa reklamo ng na feature sa abs-cbn.. yung nag change driver pa..
    Quote Originally Posted by kurt View Post
    thank you sir..
    Jun 2012
    #2451
    350 lang yung vic na ginagamit ko. Palit every 10k km
    Nov 2014
    #2452
    Quote Originally Posted by altec View Post
    Sir altec, good morning! Regarding this FDS Auto, do you have the contact number of Frederick? This is just in time as I am looking for an alternative shop (aside from casa) that does PMS in Cebu area. Thanks in advance!
    #2453
    Mga any idea po umilaw yung engine warning ng monty ko.is there any problem of the engine?or ano po nangyari bakit umiilaw?thank you advance..
    Nov 2014
    #2454
    Quote Originally Posted by boimontero1972 View Post
    baka marumi na po yung fuel filter? dalhin na lang sa casa para ma scan. hindi ko po alam kung ang shop na nirefer ni sir altec previously ay may obd2 scanner.
    #2455
    Ok po thank you
    Aug 2003
    #2456
    Fds auto landline 4064116 and 2330325. He does not have obd but as an old school mechanic he can diagnose and has found solutions that willl make the check engine warning switch off which means nakuha nya ang problema. And if he cant, he uses a contact's obd.
    he also has globe and sun mobile.
    #2457
    180 nga lang vic dito sa amin.
    Jun 2015
    #2458
    Sir Zix pa pm magkano timing belt replacement. Saka location ng shop niyo?
    Nov 2014
    #2459
    Thanks very much sir!
    #2460
    T-belt change
Montero Sport PMS Thread
