Page 124 of 162 FirstFirst ... 2474114120121122123124125126127128134 ... LastLast
Results 2,461 to 2,480 of 3240
    #2461
    T-belt change
    #2462
    Mga sirs do you have any idea on how much 10k pms will cost, im about to have 10kpms, TIA
    Aug 2004
    #2463
    Quote Originally Posted by jre.3368 View Post
    it depends on what type of oil you will use.. IIRC, it's around 7k on my 10k pms using the (casa supplied) turbo xp synthetic oil..
    #2464
    Thanks sir Elroi for the info,
    Apr 2015
    #2465
    mga sir ask ko lang po kung san sa batangas area maganda mag pa service aside from casa? thanks in advance.
    #2466
    thanks for the visit sir prince777
    TIMING BELT change
    FMIC upgrade
    Shock absorbers replace
    Feb 2007
    #2467
    As always, thanks a lot for the A-Team at ZIX Performance.
    Dec 2015
    #2468
    ilang kilometers ba bago mag replace ng timing belt? as preventive measures
    #2469
    Hello sirs,
    Question lang, where can I have my 2009 GLS-SE serviced? Mileage is 35k and I think the last time I brought it to the CASA was nung 15K pa yung mileage.
    Preferably non-CASA shop sana in Pasig/Mandaluyong/San Juan area.
    And am I right na semi-synthetic na dapat gamitin kong change oil? How much should I expect the cost to be?
    Is there anything else I should have done at this mileage?
    Sorry, sobrang napabayaan ko yung service ng Monty ko hehe.
    Aug 2014
    #2470
    Ano ba Specs ng ATF para sa 4m41? Pwede na ba Outside sa Casa at Sa Gasoline station na lang papalitan...
    #2471
    Quote Originally Posted by timming_gear View Post
    basta ba SP3 din yung fluid na gagamitin, okay yan
    Aug 2014
    #2472
    Quote Originally Posted by zix888 View Post
    Ano ba pinag kaiba ng Sp3 sa DexIII? may ganun specs kase nakalagay
    Apr 2012
    #2473
    SP3 ay pang Mitsu at Hyundai talaga yan. Ang Dexron ay pang GM. Kaya wag ka gagamit nun. Stick to the recommended.
    Aug 2014
    #2474
    Yung sa Shell. S3 lang ang nakalagay. Pwede ba to?
    Jul 2003
    #2475
    napa check narin ako ng ATF
    operating temp., short drive, R N D then hold at D while checking dipstick.
    nasa O ng cold ang level ko.
    mga 1 liter kulang ko tama?
    #2476
    Quote Originally Posted by kurt View Post
    N position mo kuhanan ng level
    Alam ko hindi yan SP3 eh. S3 code niya yan. MD3 means mercon at dexron 3 ang na-me-meet niyang requirements.
    Castrol Multivehicle ATF ang alam ko na mitsu/hyundai SP3 compatible. Semi-syn kaya medyo mahal ha.
    Jul 2003
    #2478
    Thanks zix check ko ulit.
    Overheard yun at D sa gas station nun pa change oil ako. Pajero pa din yun kaya ginaya ko
    Feb 2009
    #2479
    Guys, any experience with the new monty? Went to carworld pampanga yesterday for 1K pms. Sabi di na daw kailangan. Balik na daw sa 10k. Consistent with what is on the dash screen reminder. Pero yung Citimotors where i bought the unit says the plant still recommends 1K pms. Wala din sa manual. Worried my warranty will be voided if i follow carworld.
    May 2013
    #2480
    guys itried to look for it..ilan kilometrahe linisan ang intake manifold? may inaadjust ba o auto adjust yun?
Montero Sport PMS Thread
