Page 582 of 718 FirstFirst ... 482532572578579580581582583584585586592632682 ... LastLast
Results 11,621 to 11,640 of 14348
    #11621
    Quote Originally Posted by JB Day View Post
    Sir Testament11,
    Thank you for your input... I you we're to advise me should I push through my plan of buying one? If not what would you suggest? My budget is w/in the range of P300K-P350K... Eh Sir kung maka-chamba ako ng Dubai na diesel? Cencia na at dream car ko talaga ang pajero eh... Bukod sa dream ko siya eh yun practicality niya (laban siya sa lahat,,, baha, lubak, atbp.)...
    Thanks again!!! Happy New Year and God bless us all...
    Go for it ... kung surplus just make sure na ok ang conversion and orig lhd ang dash (15-18k bnew) .. kung dubai na diesel test drive mo muna. Some of them have leafs springs for the rear .. while local and japas surplus are usually coil sprung.. so baka magkaiba ng ride or kung palitin n springs nya (leaf) mahirapan ka makakuha..
    Local, japan surplus or dubai it really boils down sa current state ng vehicle.. bring a mechanic to be sure
    Dec 2014
    #11622
    Thank you Sir blue_gambit!!! I'll take note of that...
    Happy New Year and God bless us...
    #11623
    Sir Testament11,
    Yep go for it. Basta ito lang ang tip ko pagdating sa 2nd hand cars na medyo matanda na. Habaan ang pisi when problems arise. Di biro ang mag-maintain ng isang 15+ year old na sasakyan and it needs TLC.
    #11624
    After 1 month, nakauwi na rin ang JDM ko dito sa bahay. Ending, busted na talaga ang lumang tranny ko. Bumili nalang kami ng surplus kahapon sa Banawe for 15k, di kasama transfer case.
    #11625
    Testa, naikabit na yung bagong tranny?
    Mar 2011
    #11626
    Drum(brake) din pag leaf spring.
    Aug 2005
    #11627
    any recommendation saan makabili ng oil filter for pajero 2006 gen 3? also how much does it cost? also any recommendation for the change oil, not casa..
    #11628
    Quote Originally Posted by Monty View Post
    Oo Monty. Kahapon din naikabit. Bilis lang nga eh pero hindi lang kinabit ng mga mekaniko yun ibang turnilyo. Tinuloy nalang ng mga tao ng pinsan ko yun pagbalik ng mga binaklas. After nga nila mapatakbo kahapon sibat na yun mga mekaniko ng pinagbilhan ko ng tranny. Bilin sa akin ng pinsan ko, pa-check ko daw gear oil ng tranny at patignan kung may mga bolts na di naikabit
    Oct 2009
    #11629
    Sir testa kumusta naman yong shifting ngayon?
    Apr 2012
    #11630
    Guys any recommend brand ng reverse LED light for pajero and how much ? medyo madlim yung stock bulb ko i have tint din kasi. Thank you for the tip.
    #11631
    KILL, try this link
    Thanks man. I hope they get more service stations up in 2015.
    Sir Testament11,
    If you go for the Pajero, be prepared to spend extra for repairs. As what has been said, a Pajero will need a bit of TLC due to age. If you end up buying one, I suggest you change the fluids and filters straight away as well as clean the brakes.
    Good that you finally got your JDM back man. I'm sure you missed it.
    Quote Originally Posted by longbeard View Post
    I'm currently using Bosch which I got from Warren automotive on Benavides street in downtown Manila. Is yours the 4m41 or 6g75? I just have my oil changed at my local Petron station. If you've got the 6g75, changing the spark plugs can be a pain.
    #11632
    Quote Originally Posted by PapaPaj View Post
    Do you mean that you tinted your rear lights?
    I'm currently using all LED for my brake, park and back-up lights. It all cost me a little over 2,000 if I recall correctly. It's a lot brighter.
    Nov 2014
    #11633
    Mga sir query lang po. I want to put a turbo timer sa fm ko. Ano bang mga issue na dapat ko hanapin sa turbo timer that i would be getting? Any compatible brand for our fm?
    Secondly mga sir i want to install a car alarm/remote kasi when i got my fm eh de susi na mag open ng door though i think my alarm pa to kasi sometimes ng hahazard xa when i open the door then d ko xa ma istart unless i press the disarm button.
    Ask lng po, ano po kayanh klase na alarm na nka install ngayon sa gm ko and then ano po ma recommend nyo na ipalit ko po.
    Thanks n advance po. Happy new year to all
    Dec 2014
    #11634
    Quote Originally Posted by K.I.L.L. View Post
    Thanks Sir K.I.L.L.
    Around how how should I make ready for those extra repairs? Thanks!!!
    #11635
    Thanks Sir K.I.L.L.
    There is no answer for that as this would depend on the condition of the FM that you get.
    #11636
    Quote Originally Posted by rols View Post
    Uy, long time no post Doc! Shifting is ok. Wala na yun problema ko na hindi nagshi-shift pag bagong start ng engine. Pero kelangnan ko siguro mag-adjust sa TPS kasi 2nd going to 3rd kelangan ng konting push. Pero overall, ok na ok na ang takbo.
    Yeah, I missed it a lot. Good thing its already in good condition.
    Quote Originally Posted by birman View Post
    Turbo timer, kahit ano pwede naman. Apexi, HKS, original o class A pwede naman.
    Tapos sa alarm, kung OEM hanap mo, Code Alarm ang OEM alarm ng FM. Pero kung ako, mag Autopage ka nalang. Yun ang nakakabit ngayon sa JDM ko
    #11637
    Testa, +1!
    Nov 2014
    #11638
    Thanks sir testa. Happy new to all!!!
    Aug 2007
    #11639
    Mapayapa at Masaganang Bagong Taon po sa ating lahat!
    Ok po ba magpa calibrate sa Zexel Marcos Hiway? Maraming salamat po.
    Nov 2014
    #11640
    Mga sir ask ko lng. Yung orig na alarm ba ng local 99 fm eh may disarm button sa lower
    Portion ng alarm light?
    Yung sakin ksi meron sabi ng isang electrician kilapitan ko eh d dw orig yun. Pls....tnx!
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
