anyone tried using top 1 synthetic blend diesel oil? im due for oil change this month.
Based from experience, had a comment on this in another thread (best engine oil for 4D56 engine?).
take note lang mga chiefs that this is only semi-synth oil; most car owners tend to overlook it. Price wise, it is selling like pancakes nowadays because of cheaper price compared to other semi-synths available in the market.
Guys - I need your help.
I own local fieldmaster (4m40) with 175K mileage.
The engine is eating oil and experiencing hard starting.
Once started i have to rev the engine up to 2Krpm for 5 minutes
as otherwise the engine will die. I live in QC and would like to get
your recommendation on best engine mechanic in QC or nearby area.
Thanks in advance Gurus.
I don't recognize any significant change in fuel consumption for last 8years im driving this rig - still averages 7.5km/liter.
Where can i bring the rig to check the injection pump seal?
I just need a mechanic that can diagnose if the problem is due to engine
loose compression or fuel injection problem.
The car will start naman in 1 click - but have to step on the accelerator as otherwise the engine will die (low rpm). And once the engine dies the next start would be harder and once re-started it will spew black smoke.
Pero ano ba ang sintomas ng bad injection pump?
Pag kasi uminit na ang makina maayos na ang takbo.
On oil consumption - i top-up 1 liter every 6 weeks (approximately 1500km). I said the engine consume oil as there is no oil leak mark visible at engine bay. I think water is being consumed also.
Thanks for the help folks.
sir kasi sabi mo, hirap sa mga 2nd or 3rd starts diba? and you have to step on the accelerator pa? meaning kulang sa supply ng diesel sa start. Injection pump kasi nagssuply ng fuel. or injectors mo restricted.
pag sa first start lang mahirap, glow plugs/heater related yan.
alaga ba sa tune up yan? when was the last time na nagpa-tune up?
-change oil
-change air filter
-change fuel filter
and also, anong diesel gamit mo?
For the consumption on oil, baka lose compression na? kailangan magpa-compression test ka.
