Page 501 of 718 FirstFirst ... 401451491497498499500501502503504505511551601 ... LastLast
Results 10,001 to 10,020 of 14348
    #10001
    Quote Originally Posted by K.I.L.L. View Post
    Where will they do the installation? Do they have a shop here in Manila too?
    As for Monsterworx, may shop sila sa Las Pinas, IIRC..
    Quote Originally Posted by rex02 View Post
    Mga sir good am tanong lang ho pag nag overheat ba yong engine natin ano b ho ang maging weak parts sa loob engine thanks, cause nga po pala nag evaporate water kasi na untighten yong radiator cap
    Cylinder head ang prone dyan due to warping, pero hindi naman basta basta nagwawarp yan nang ganun kabilis.
    #10002
    *kill, lift na? Hehe
    Sent from my Nexus 5 using Tsikot Forums mobile app
    #10003
    Haha... I'm still on the fence. It can be both awkward and hard to get in a high rig when you're wearing business clothes.
    I still have to fix a few things in the interior first. My cup holder is still broken and I might just ask JA to get me one as well as a few other parts when he goes to China. When I visited him, he had the fog lights I was looking for though he didn't have the OEM switch. He told me I can convert it to yellow HIDs though it would need modification. I'll probably pay him a quick visit this weekend.
    #10004
    Ah... good to know that we have options.
    #10005
    guys tumutulo po harap ng engine ng fieldmaster ko... sa may halfmoon area.. mahina lang naman leak pero papano po kaya solusyon?
    thanks
    #10006
    Quote Originally Posted by AC View Post
    thanks
    Check my post AC kakapagawa ko lang nyan yesterday
    Posted via Tsikot Mobile App
    #10007
    sorry sir bg.. di nakapagbackread.. hehehe.. ang linaw linaw pala listed with pictures pa.. just the page before.. hehehe
    sir... ano po yung "R" na parts for 150php? silicone? di napo ba kailangan ng silicone to have it back in?
    u mean mitsuparts.. ? diamond motors? mga ganun po?
    thank you:D
    #10008
    Naayos na din ang bushings ng suspension arms ko. OEM bushings is 650 petot each ke Mit-Parts, so 4 kelangan ko. Napabili din tuloy ako ng 2 coolant tank cover at 3 valve cover seal. Sayang kinulang pa ng isa...
    May nagbebenta na ng Ironman sa Banawe, Speedtrap 4x4, yun pinagbilhan ko ng Ralliart rims. Kamote sa taas ng presyo ng Ironman nila, 57k for the whole set! :hammer:
    Apr 2012
    #10009
    guys im planning to buy compact pressure washer. nadaan ako sa ace hardware meron silang black and decker 100 bar pressure washer for 5k ? is it worth it ba or mahal? direcho sa gripo ang kabit..
    baka may mairerecommend kayo na matibay, malakas ang pressure at portable. Thank you
    #10010
    Ah... that's why they're call speedTRAP with plenty of emphasis on the trap.
    Quote Originally Posted by PapaPaj View Post
    I know Karcher is good for pressure washers but they're expensive. I used to have a black & decker dustbuster which lasted ages. I currently still have a 10 year old black & decker cordless screwdriver and it still works great.
    #10011
    Orig nabili mo na valve cover seal sir?
    #10012
    Oo, same sa nipost mo. Yun nga lang, kinapos ng isang piraso para mapalitan ko din yun sa isang Pajero
    #10013
    Thats gud, gumamit ako ng replacement seal. Di maganda kapit sa bolt nag pawis pa rin. Kaya pinalitan ko ng orig...
    naunahan mo tuloy c AC kelangan din nya nyan for sure...
    Apr 2008
    #10014
    Guys sa cash n carry 230 ang isang quart ng top1 synthetic oil, ok ba yon? Red ung markings nya
    Mar 2003
    #10015
    May napansin ako sa pajero ko. Nawala yung timer ng glow plug ko. Pag on ng susi may first click sound. Di narin umiilaw yung heater light ko. Then dapat after 5 secs bibitaw siya. Yung akin ayaw na. Tuloy tuloy ang power.
    But after mo istart naririnig ko bumibitaw siya pag umandar na ako mga 1 min. Or 1/4 ng temp.
    I guess buo yung sending unit sa coolant. And ok yung relays ko. Ang problem sa tingin ko ay yung mismong gp ecu na.
    May nakiseries saakim na car a few days back. Hula ko baka nadamay yung electrical ng gp ko. Bagong start car ko nun siguro umaandar yung gp ko nun. Baka may bumalik na kuryente from the other car. Hula ko lang to.
    Any idea kung nasaan yung 5 secs timer nakalagay?
    Jun 2004
    #10016
    No idea where the GP timer is located. Most likely relay ang nasira. Before this happened how long nag light up ang heater light mo? Sa akin kasi sobrang bilis lang ever since brand new ang rig - as in sandali lang talaga. Pa check mo relay itself and connections to be sure. Kailangan magaling na electrician ang tumingin nyan. Kung mapadpad ka sa Manila bring it to Rey's - 15th Ave Cubao.
    Jun 2004
    #10017
    Laki na pala tinaas ng IronMan lift kit. Had mine installed March 2011. Only spent mga P35-37k lang for the whole kit. Suggest you go directly to the dealers - Dr. G's or better yet get in touch with IronMan Phils (owner is Paul) - active siya sa 4x4ph site and 4x4ph FB group. Note that there's no need for a steering stabilizer. Tip - don't go for the foam cell shocks. Mas malambot ang Nitro Charger and mas mura pa.
    Dec 2009
    #10018
    *all Sir ask ko lang po kung ano mga part number ng mga belt ng pajero? (Yun sa fan, aircon at yun isa pa?) 3belt na po papalitan ko para isang bilihan na lang? What brand po kaya maganda? Thanks!
    #10019
    Sir pano mo nalaman na tuloy tuloy yung power sa glowplugs? how did you test it? parang naman i-series ang battery naten pag tutulong tyo... hmmmm
    *autokits try mo mitsuboshi V-blets yun ang gamit ko... as per AC it seems orig japan
    Dec 2009
    #10020
    Thanks sir testa. Will ask nalang sir AC saan available para isang luwas nalang..
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
