Page 521 of 718 FirstFirst ... 421471511517518519520521522523524525531571621 ... LastLast
Results 10,401 to 10,420 of 14348
    #10401
    Anybody here from PCP? Down ba site nyo? Was browsing and cant find it.. or thru FB na lang din
    Posted via Tsikot Mobile App
    PPAC din down yata?
    Sent from my Nexus 7 using Tapatalk 2
    #10402
    wala naman problem. a replacement rad will cost you around 12k. ang mahal.
    pag kay Keyser, at least orig pa yung rad mo.
    Nagcanvass na ako and will opt for the replacement of the whole radiator assembly (Original Denso)
    Keyser (Cool Charge na pala pangalan ngayon) quoted me 8.5k for the repair of the plastic top...
    Denso Quezon Ave. quoted me 13k for the radiator assembly replacement...
    Medyo namahalan ako for the cost of a "repair" so I decided to go through with the replacement na lang for peace of mind in the long run.
    By the way, the Coolmate Group Denso (Main Office in Makati) does not repair/carry/replace our Pajero's radiator.
    Ang meron ng radiator assembly natin (but does not repair) ay yung Den-Aire Group Denso (Main Office in Quezon Ave)
    FYI... So for those that will have problems with their radiators in the future, better get in touch with either Keyser or Den-Aire Group Denso.
    #10403
    PPAC din down yata?
    The webmaster suggested to browse it using google chrome.
    #10404
    Quote Originally Posted by junerski View Post
    mahal na pala ngayon. with that price, get a brand new nalang. 13k basta orig Denso ok na. kasama na ba install? have them flush out the heater system as well.
    oh, yung bleeding ng cooling system matagal. im sure alam na ng installer yan.
    #10405
    Quote Originally Posted by spooning_around View Post
    Hi guys!!! nabali yun door handle (exterior) ko ouch, looked for parts pero wala ako makita na japan made, puro taiwan offer sakin. si Bestcolt pinakamura na offer which is 320 pesos only. inquired also kay Cinco pero wala pa daw sila Japan made which costs naman 800 pesos. can you help me guys in sourcing out my broken handle?? TIA
    Hi guys, update ko lang. kinuha ko na yung taiwan made outer door handle * P 300 pesos only + installation fee of P 150. Total cost = P 450 pwede na, kesa kumuha ako ng orig. chineck ko yung nasira ko na orig ang compared it with the replacement part and halos pareho lang. kay Bestcolt ko pala kinuha
    #10406
    Ok thanks CB... I'll update the thread for our guidance... I'll have it installed this Thursday.
    #10407
    With that price of repair its really better to get the new one! Sobra mahal!
    #10408
    This is good information man! I'm sure a lot of us here have had, are having or will have problems related to the radiator. Thank you very much! I'm keen on hearing how your installation goes.
    #10409
    junerski, brief explanation lang sa bleeding ng air ng radiator.
    you need to idle the engine with the rad cap open for around 60-90 mins. aircon on - off once in a while then heater mode din para umikot yung coolant until mag normalize yung water level. add coolant when necessary. para mawala air pockets.
    May 2008
    #10410
    Greetings
    Do you know where to buy a 2nd hand step board right side
    Jan 2011
    #10411
    Mga bossing!
    Paunahan na lang kayo oh!
    Mura na.. Orig pa! Free pa fog lights..
    Kung nasa manila lang ako.. hehehe
    Pajero Arb Bumper - Secondhand For Sale Philippines - 44449755
    Feb 2014
    #10412
    Guys, ayos lang ba pag medyo lumakas yung whistle sound nung turbo? Wala naman siyang pinagbago sa hatak and takbo. Wala rin palang usok. Okay lang kaya ito?
    Ganito po pala yung tunog niya.
    http://m.youtube.com/watch?feature=y...&v=cc4ykrnn_3c
    #10413
    Or you can drive it around till engine temp is normal around 1km. Park your car overnight, then top-up in the morning .. thats what i do...
    Feb 2014
    #10414
    Hi to all pajero owners. Newbie pajero owner here. I acquired my Pajero JDM 4m40 (A/T) last December, sa ngayon pinagaaralan ko pa yung sasakyan since ilang buwan pa lang siya sa kin. So far ok naman siya, puro minor repairs pa lang ang ginagawa. Planning to do some upgrades and maintenance at the same time. Meron lang akong mga tanong sana po masagot nyo.
    1. Last January pinaflush ko yung radiator and I found out na wla pla thermostat yung unit ko, so nilagyan ko na lang. before ko cya nilagyan eh nasa 1/4 lang palagi yung temp then after ko lagyan eh normal na yung temp almost half. pero matagal ba tlga mareach yung normal temp from cold start? yung 1/4 temp halos 10 mins before mareach from cold start. ang tagal ko mgwarm up in short, normal ba un?
    2. San po ba mas maganda mgpakabit ng devils own, sa speed lab or berrima?
    3. Any idea how much manual boost controller at san maganda bumili?
    4. Sa turbo timer ok lang ba kahit copy ang gamitin?
    5. Gaano kadalas dapat magpalit ng gear/differential oil?
    Thanks in advance!
    Apr 2012
    #10415
    anyone looking for a manual boost controller? meron ako available na turbosmart TS-0101-1002 black boost tee. bought it pero di pala applicable sa vgt unit ko. pm me if interested ;)
    #10416
    Quote Originally Posted by chris143135 View Post
    Thanks in advance!
    Same tayo ng Pajero sir, so pwede kita matulungan dito.
    1. Medyo may katagalan nga. Ako kasi, wala pang 10 mins. nasa normal operating temp na ko. Nacheck mo ba kung ilan ang idle RPM mo? Baka kasi medyo mababa, should be at least 800-900RPM ang normal RPM, lowest is 750 from cold start
    2. Berrima. Daming horror stories ng Speedlab kasi. Pero kung kaya mo ikaw nalang mag-install, better na ikaw nalang. Di ko rin kasi masyado gusto yun pagkaka-install ko nung sa akin ni Berrima kasi parang basta maikabit lang yun motor at reservoir tank. Inayos pa namin ng erpats ko yun pagkakalagay ng mga yun from scratch. Electricals, maayos naman nailagay ni Berrima.
    3. Ayun, nag-post na si Monty
    4. Turbo timer, sabi ok lang na kahit copy lang. Pero if you have the money to burn, get the original ones
    5. I think its around 40k kms before you change those oils. Pero kung madalas kang lumusong sa baha, baka yearly ka magpalit.
    May 2008
    #10417
    Reposting my query
    anyone you know who supplies step board for the pajero
    Quote Originally Posted by santosestrella View Post
    Reposting my query
    Sa casa siyempre, tapos hanap ka sa olx or other online buy and sell websites.
    #10419
    Reverted back to my original plan of having my radiator plastic top repaired by Keyser (Cool Charge) because a friend of a friend personally knows the owner (Mr.Keyser) and a lot of items have been done free of charge (as part of their general radiator service)
    Working time: 4hours including bleeding time (as pointed out by CB; halos 1 hour ata nagbleed for bubbles/airpockets)
    Number of mechanics who worked on it: 3pax including personal inspection by Mr. Keyser (siya mismo nagmando ng bleed)
    Total Cost All in: P6,000
    Overhaul/Labor: P2,000++
    Top Tank Cover: P3,000++
    Refilling Viscosity Fan: Free (they usually charge P1,100)
    Coolant/Distilled Water: Free (they usually charge P900 3L of Coolant)
    Gasket: Free (they usually charge P1,300)
    Flushing: Free (they usually charge P390)
    **Replace Fan Blade: P1,000 (additional and not part of general service; may crack na yung blade ko)
    So kung wala discount/freebies, aabot nga ng 8.5-9k ang general service
    new plastic top
    new blade
    old blade (with hairline cracks)
    bleeding period
    leaktest tool
    engine operating temp after (espana traffic midday, bumaba pa ng konti temp ko after the service)
    #10420
    Im very happy naman with their service... all things in the cooling system are checked including hoses, radiator cap and thermostat.
    Mr.Keyser also mentioned to have the fan blade regularly checked marami raw kasi siya naexperience hindi dahil sa may leak eh dahil nga damaged/basag na yung blade nagoverheat (yung sa akin papunta na dun kaya pinapalitan ko na)
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
