Page 376 of 718 FirstFirst ... 276326366372373374375376377378379380386426476 ... LastLast
Results 7,501 to 7,520 of 14348
    Dec 2009
    #7501
    *bg sir 4d56 nabasa ko sa hood di ko sure kung 2.5 o 2.8 ito ano po ba pag jdm? Also hindi naman naka handbrake but may ilaw yun ("!")? Weird naman. Plan po kase paltan lahat ng oil since turnover na sa akin para recorded mga ginawa sa pajero.
    #7502
    Quote Originally Posted by autokits View Post
    pag nakailaw yung handbrake, baka mababa yung brake fluid mo.
    Dec 2009
    #7503
    *cb copy sir will check on that. Sir ano prefer nyo top1o yun royal purple ba tun? At anong brand ng oil filter? Un VIC ok ba un un kase ang madalas ko makita? May ibang brand pa ba? And anong part # if alam niyo dun? Thanks!
    #7504
    or mas simple baka naman sira na yung switch diyan sa ilalim ng handbrake kaya naka ground siya lagi kaya iilaw talaga
    #7505
    pareho naman maganda ang Top1 SDO and Royal Purple. Nasa budget lang yan. kung kaya naman ng budget, pwede mag Royal Purple.
    pero ako, sa Top1 nalang. wala akong budget e
    #7506
    Out with the old.
    #7507
    2.5 pag 4D56, yung 4M40 naman 2.8 bro... kung me budget royal purple... hehehe
    I'd prefer Baldwin BD28 kung me mahanap ka...
    Dec 2009
    #7508
    Salamat. Sir bg, cb and zix wala na yun ("!") nagbanto na ako ng brakefluid. Can you enlighten me re: shifting ng gear para san un 2h 4llc ba yun? Puro D and 2H lang kase un stick ko never ko pa na try un L=? And 2=?abigyan nyo lang ako idea when will i use that. Sorry super bago sa a/t lalo na 4x4.
    #7509
    Pag normal driving, nasa D at 2H lang yan pag normal driving. Tsaka mo lang ilalagay yan sa L o 2 pag let's say paakyat ka para hindi siya mag-shift to higher gears or engine braking pag pababa ka sa matarik na kalsada. L stands for LOW o 1st gear only. 2 means magshi-shift siya from 1st to 2nd lang.
    Yun 2H, 4H, 4HLc, 4LLc, yan yung 4wd modes. 2H means 2wd only. 4H means 4wd mode pero nasa High (correct me kung mali ako guys). 4HLc means naka 4wd mode ka in LH then naka-lock ang center differential mo. 4LLc means 4wd mode pero naka-low at locked ang center differential.
    Normally, 2H lang dapat yan. Pero kung halimbawa, slippery yun kalsada, pwede mo i-engage to 4H yan para sa dagdag traction. Wag mo gagamitin ang 4HLc at 4LLc in normal conditions. Ginagamit lang yan pag yun tipong pang off roading na talaga.
    #7510
    tuloy ba tayo bukas?
    #7511
    Bakit naman hindi all set na yung EB. See you all tomorrow.
    #7512
    1. Rols
    2. Nelany
    3. AC
    4. blue_gambit
    5 crazy_boy
    6. jilibee
    7. Richie <--- from PPAC
    8. Numbskool <--- from PPAC
    9. Gelo <--- from PPAC
    10. K.I.L.L.
    11. zix888
    12. gab
    13. jappy
    Up natin baka me sumama pang iba sa EB sa June 12, 4:00pm sa Burger King, Timog.
    Up lang uli natin as a reminder sa EB bukas.
    Dec 2009
    #7513
    *testa salamat sir dapat pala naka L kami pag pataas like sa mall parking yun pala ang 1stgear
    #7514
    Hindi naman kelangan nasa L ka pag aakyat ka sa mall parking. Ok na ang nasa D lang
    Dec 2009
    #7515
    ^so yun tipong tagaytay "sungay" dun dapat gamitin ang L kase matarik talaga dun eh.. Nalilinis ba ang turbo sir un nakapating sa makina? Di ko kase ramdam kung anong diff ng may turbo at wala eh.
    #7516
    Papuntang Tagaytay ba? Di naman din kelangan. Ako, gumagamit ako ng L o 2 pag lulusong sa baha. Nung bumaba ako galing ng Mt. Samat, nasa L din yun shifter ko para sa engine braking.
    Hindi turbo yun nakapatong sa makina. Intercooler yun. Kung yun nalilinis, pwede naman.
    Oct 2009
    #7517
    see you tomorrow guys...
    #7518
    Gentlemen, my apologies but I might not be able to make it. I have some foreign guests that I have to take care of.
    Dec 2009
    #7519
    *testa sir intercooler pala yun pano ba malaman if working ang turbo di ko kase ramdam if ever meron mabilis na ang takbo ko once i reached 100+ ganun.
    #7520
    Do you hear a whistling sound when you reach 80?
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
