Hello All,
Just got myself a Pajero FM a couple of days ago. First one that I spent on with my hard earned money and really happy with it. As with second hand cars there are minor quirks to which I would like to ask you guys...
Fuel Gauge
- tank was near empty when I got it so I filled it up with P700 worth of diesel...indicated reached almost 1/4...all is good
- the next morning I was surprised that it's back to near the red line again...later that day, it's again back to almost 1/4
- with this I'm planning to replace the fuel float...is this the best solution or there are others I should look into?
Aircon Vents/ Louvers
- aircon is ok...nitpick is some of the louvers are fixed
- i'm planning to have this replaced...browsing through this thread it seems price ranges from P1,500-P3,500 per piece but those are a couple of years ago
- any idea on the current price of these spare parts? it's not really a necessity but its the OC part in me that wants to replace them
Turning Off the Engine
- when I turn off the engine, there's this loud/ growling sound while doing so...is it normal?
I'm quite a newbie with regards to cars so I look forward to everyone's feedback/ suggestions. I do hope to contribute as I learn this great machine.
Regards,
Dino
RE: Fuel gauge
Most likely baka sira nga ang float. Have it replaced nalang. I know someone here who recently changed/repaired his fuel float.
RE: Growling sound
Paanong growling? As in pagkatapos mag-off eh tsaka papasok yun sound?
RE: Aircon vents
I think nasa ganyan pa rin ang price niyan. Di naman masyado tumataas ang mga ganyang parts.
fellas,
alive parin conversation dito.
owner of Gen 2 here,
may tanong lang ako, nag pa casa tune up ako dito sa province, isabela, then pa check ko na rin un leak sa ilalim, bale un leak is coming from crankcase,
oil pan ng engine. pina qoute ko, 2500 labor. kasi ibaba pa un front diff. 2 days work
kaso wala silang gasket available, buwisit.so ang sinabi nun taga gawa dun, un silicon nlng daw ilagay, na PIONEER brand, mighty gasket ang name.
black in color un lagayan..i believed nakita ko to previous dun sa post ni junersky.okay lang ba tong gamitin? hindi ko muna pinagawa, ask ko muna dito.
isasabay ko na sana pati mga front/ rear diff at transfer case, problema eh un gear oil nila ehGL3 75-80W, mitsubishi un tatak.sabi nila, bago to at eto na ginagamit nila for both differential and transfer case... kasi un nabasa ko dito, sa front/rear diff 90W GL5 at un tranny 90W GL4.. patulong nman dito. hirap din hagilapin ng gear oil na yan dito sa province. anu sa tingin nyo un GL3 na sinasab nila
pina check ko narin, smoke test while ideal at revs ng mataas, mausok sya, pero kpag ideal na walang apak sa revs eh hinde.
sabi ni kuyang, un injection pump na raw baka for inspection na. nasa 17K daw lahat lahat kung pati pati injection, which is almost same price sa
mga nakikita ko dito na for calibration.
as previously na na mentioned ko, i dont feel the hataw mode din ng fm ko, khit nun pauwi ako after tune-up, parang walang nagbago.
TIA, nobela na yata.hehehehe
correction pala sa sinabi ko, un sinasabi dito transfer case is 90W GL4. not the tranny, naguluhan na ako.
tanong ko na din, kung anung klaseng oil para sa manual transmission.
thanks
i think dapat parehas lang... tanong tanong na rin sa parts people ng mitsu casa just to be sure... kasi come to think of it, isa lang naman parts catalogue ng Pajero may it be local or JDM.... BTW, order basis yan sa casa and independent mitsubishi parts sellers like motorix (based on my experience) hindi sila nagbebenta nyan... hinuhugasan lang daw nila
ballpark figure for gasket and filter siguro 2k lahat (may sukli na yan)
Hi to all pajero owner enthusiast share ko lang mga mura kong binilhan ng basic consumable parts ng pajero ko baka makakatulong sa inyo
OEM parts na binili ko sa contact ko when I did my replacement during PMS
Oil Filter - 900 Php
Fuel Filter - 1600 Php
Sensor Shocks absorber Front 7500 Php/pc
Headlight Washer - 800 Php/pc
Meron pala akong nakitang Intercooler turbo stainless pipe costing 3500 (+ swap my rubber hose) second Hand. OK na bang price na yan? makakatulong ba yan to eliminate the turbo lag?
if ever may interesado sa mga OEM parts above tawagan nyo tong number ng supplier 2544730 or 09228829765 (SUN)
Hope this will help.
mga sirs may mura akong kinukuhanan nyan 3K lang OEM na. kakapalit ko lang ng lahat ng supports ko.
sa bandang Tayuman siya sir. Wala syang Shop. pinakilala lang din sa aking ng kapatid ko. basta tumatawag lang ako sa kanya bago ako magkacanvass sa iba kung may stock sya. proven ko na mura sya. ang huli kong nakita sa stocks nya available ay mga filters.
ang huli kong binili sa kanya ay auto lock actuator sa driver side. 3,700pesos lang. nasa 4,200pesos sa dorado at motorix
mga sirs, UP ko lang yung inquiry ko regarding stainless piping ng intercooler natin. May improvements ba to sa sa performance or aesthetics lang? your comments are highly appreciated.
650 quote nila sa akin ng labor. Mejo masungit yung lalaki nakausap ko. Anak yata nung mayari. Kasi i brought my own oil and oil filter kanina. Labor lang sa kanila. Sinabihan ako na next time hindi na daw pwede.
Pag sira yung tranny support, malakas vibration. Lalo na kung nasa D or R
Sir may pictures kayo nung mga parts na OEM?
