Page 287 of 718 FirstFirst ... 187237277283284285286287288289290291297337387 ... LastLast
Results 5,721 to 5,740 of 14348
    Aug 2009
    #5721
    been to motorix
    1) clip with hubcap 550
    2) mobil atf220 = 280 per liter (sir, pwde ba gamitan ng dextron III ang pjero fieldmaster? gusto ko sana gamitan ng brnad mag 1 na dextron 3)
    3) no wheel sensor
    4) mahal pala ung air filter (1000) i think i remember sa Casa probably 750
    #5722
    Quote Originally Posted by baby_scar View Post
    been to motorix
    3) no wheel sensor
    You can buy replacement air filter for a lot cheaper. Nasa 150 lang.
    Yung wheel sensor sa winterpine ka siguro makakahan nun.
    - - - Updated - - -
    been to motorix
    3) no wheel sensor
    Aug 2009
    #5723
    - - - Updated - - -
    ano brand po yan sir? saan po ung winterpine? banaue? address?
    #5724
    winterpine is along g.araneta ave qc.
    been to motorix
    3) no wheel sensor
    I'm using caltex texamatic 1888, it's Dexron-III certified and so far, 36,000+ kms of using it and the ATF looks okay and there's no shifting problem. Will change at 40,000kms as recommended by manual. Sayang yung ATF is hindi pa naman kelangan palitan IMO.
    http://www.caltex.com.au/PRODUCTSAND...n.aspx?ID=1766
    #5726
    been to motorix
    minsan masmahal pa sa autosupply ang parts kaysa sa casa (sa experience ko especially with honda parts) ...so canvass din ng pricing ng casa as compared to your suking autosupply.
    winterpine halos dulo na ng araneta ave (if your bearing is bound for sta.mesa) 716-4831.... tawag muna para hindi sayang ang gasolina
    #5727
    BG, yung Philips XV mo ba maganda parin output? and made in poland ba nabili mo?
    Aug 2009
    #5728
    casa q ave price
    air cleaner filter = 970
    atf fluid - 557
    atf filter = 2k
    motorix price
    air cleaner =1k
    atf fluid = 280
    atf filter - not availabe
    how many liters should i need for a atf change with atf dialysis?
    #5729
    casa q ave price
    atf fluid - 557
    atf filter = 2k
    motorix price
    air cleaner =1k
    atf fluid = 280
    sir, apple to apple ba comparison nung ATF fluid? and hindi 2k ang price ng ATF filter. si junerski nagpalit na. less than 1k lang
    #5730
    BG, di ba JDM din Pajero mo? May tanong lang ako...
    Kamusta ang birada ng sasakyan mo? Bitin din ba ng isang ikot o sakto lang? Nagplaplano kasi akong palitan ang harap ko ng pareho sa Gen 2 local para lang maayos yun birada.
    Tsaka tanong ko lang din, magkano kickdown cable ng Pajero sa ngayon?
    Aug 2009
    #5731
    mga sirs, been experiencing caliper brake noise every start-up but just for a minute or two at the front wheels. overhauled the calipers and changed as well the pads but still there was this noise. any recommendation remedy on this please? TIA po.
    Aug 2009
    #5732
    900 ung atf filter sa casa. nagkamali. i ask sa casa un ang binigay na price atf. tapos ung sa motorix mobil 220
    #5733
    Mobil220 din sa casa? If i remember correctly, parang 700+ yung filter tapos may gasket pa yata. More or less 900+ nga yata yung set. Antayin natin confirmation ni junerski
    - - - Updated - - -
    #5734
    motorix is cheaper than CASA? ah ok. they dont sell atf filter sa motorix. ok. i will try to visit sa casa. how much po ung mobil 1 atf220?
    sir. any suggstion about the wheel sensor? bakit nos? battery or palitan ung isang sensor? yeah, they dont. kasi i ask one time about the clip. wala sla stock
    El dorado has the atf filter. I just asked recently though I can't remember the price.
    Nov 2004
    #5735
    mga ser ok na clutch ko. orig clutch disc at orig release bearing nilagay lumobo tuloy gastos di kasi ubra yung aisin disc, exedy clutch cover/pressure plate.
    problema ko po ngayon yung crossjoint/universal joint na sinabay na palitan nung nagpagawa ako ng clutch, gmb japan ang brand nung crossjoint dalawa na pinalitan.
    nung matapos, upon test drive at high speed simula 90kph may nadinig ako ugong/vibration, kala ko nung una pilot bearing sa clutch pero nung nagbasa ko online posible na sa crossjoint/drive shaft magmula. mas madali troubleshoot crossjoint kaya yun muna kesa pilot bearing clutch. sinubukan nila baliktarin yung "yok" daw ng crossjoint, test drive ko ulit ayun halos wala na yung ugong sa highspeed pero may konti pa din kaya ruled out na clutch pilot bearing. nabasa ko na pag vibration/ugong at high speed posible din na imbalanced driveshaft o kabit ng crossjoints, dapat daw bago kalasin minamarkahan yung pagkatapat tapat ng butas at yun din mismo pagbinalik..
    problema di ata ganun ginawa kaya mahirap na kung sila pa din asahan ko para mawala totally yung vibration ng driveshaft/u-joint..
    san ko kaya pede ipa reinstall kalas kabit yung sanay kabisado para maitama yung gawa ng u-joint, driveshaft etc.. ina-align balance pa ata yun. salamat.
    Sent from my iPhone using Forum Runner
    #5736
    based on my records way back march 3,2011
    parts bought from Diamond Motors Marcos Highway (ordered in advance)
    for our reference na rin...
    Part Description - Part Number - Price
    1. Filter Oil A/T Valve Body MR166573 P786.00
    2. Gasket A/T Valve Body MR166571 P503.00
    A/T Filter
    Gasket
    Oil Pan pulled down (Before)
    After cleaning
    #5737
    *halimaw... kung sa south area... kay joseph atutubo (multinational village paranaque)... although madalas by appointment
    kung qc area... pwede kay MCM (banawe yan side ng mcdo) ....look for merrick
    kung east area (pasig/marikina/antipolo) pwede kay eco-tech bosch service (15min from masinag intersection) ...look for jay
    lahat ng yan eh may pajero and marunong sa pajero... so for sure hindi ka lolokohin.
    #5738
    Ayus naman mag 2 years na rin sya saken. Sa Low beam medyo bitin pero compared to stock its really brighter, Sa High Beam naman Solb ako, kahit sa pitch black na condition like NLEX night time malayo talaga ang bato ng beam. Pero syempre Iba pa rin ang HiD...
    #5739
    Yup port Irene unit. Ok naman Birada, sakto lang. Na check naman ni Joseph A. sabi nya tama naman daw yung gearbox na ginamit saken. Gaano kalake ba birada ng Unit mo?
    #5740
    Comparing sa FM namin, mga 1 ikot ang kulang niya. Pag nga mag U-turn ako, ang bagsak ko eh middle lane na. Pag liliko naman ako ng pa-kanan, lalo pag sharp yun kanto, kelangan may konting bwelo pa ko.
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
