Page 337 of 718 FirstFirst ... 237287327333334335336337338339340341347387437 ... LastLast
Results 6,721 to 6,740 of 14348
    #6721
    Quote Originally Posted by rols View Post
    CB si Richcar meron pang isang set ng RALLIART gauges binebenta nya sa akin 15K kaso may order na ako sa Japan same jan sa pinost mong gauges tsaka recaro seats at carbon fiber aircon louver na galing sa pajero evo sana meron na sa next shipment
    doc rols, ang mahal naman sa richcar. nakita ko nga yung carbon fiber aircon louver na pang pajero evo. nakaganun si joseph a. ang ganda nga hehe
    Feb 2013
    #6722
    Php 350 yung underwash, dyan sa Felix Ave. Depende sa setting ng WAI yung ika titipid niya. Yung sa stage 1 ko nasa 10 psi ang full activation niya, Sa stage 2 yung setting ko ay 7 psi at 10 psi ang setting niya.
    Sorry to butt in but what's WAI?
    #6723
    Quote Originally Posted by gearguru View Post
    its Water Alcohol Injection. you can read more here sir.
    http://tsikot.com/forums/engine-fuel...sel-use-46996/
    Feb 2013
    #6724
    Thank you...another thing learned...loving you guys and this forum
    Oct 2009
    #6725
    oo medyo may kamahalan nga price nila don yon nga lang kong may mga hard to find kang parts kayang kaya ka nyang ihanapan
    #6726
    Nag linis ako ng KNN air filter ko kahapon, hanep talaga sa dumi ng kalsada naten dito sa Metro Manila. Di talaga pede sundin yung clean filter element at 40T kms...
    Pero effective ang Ariel powder...hahaha
    Oct 2009
    #6727
    BG after mong mag Ariel Sir naglalagay ka pa ba ng oil hindi kaya masira don sa sabon hehehe yong sakin every after 2 months ang linis ko kaya ang bilis maubos nong recharger kit ko
    #6728
    Oo nga baka mag degrade yung efficiency niya ng maaga.
    Feb 2013
    #6729
    Sorry guys if this has been asked already (search function is directing me to a google search engine link) but do you turn off your AC before turning off your engine? Same goes with before turning it on? My concern actually lies on the on/off switch specially that in the rear. Seems too flimsy for me to always turn it off or on.
    #6730
    This is so cool...does this replace the inclinometer, temperature and altimeter gauge assembly? Only thing I find weird is the temperature gauge...it's listed as Celsius but the figures reflect Fahrenheit figures...or I'm missing something?
    those temp figures are correct (C). normal operating temps of a diesel engine usually ranges from 85-90 degree celcius, sometimes even 100 at a long period of high speeds
    Feb 2007
    #6731
    May naka experience na ba sa inyo pag shini-shift sa reverse nanginginig yung engine? Ang lakas sobra. Busted engine/transmission support kaya?
    Sent from my iPhone using Tapatalk 2
    #6732
    Quote Originally Posted by freeloader View Post
    mostly likely mas sira na support. either engine or tranny support.
    Feb 2013
    #6733
    Quote Originally Posted by zix888 View Post
    This answers my question that this is not a replacement of the meter combination cluster found on top of the dashboard. Thanks for the info
    #6734
    Ako, yes. Practice ko na ito ever since natuto ako mag-drive. Correct me if I'm wrong ah. Once you switch on your engine with your AC on, gumagana na yun compressor mo. Meaning eh kumakain agad ng battery energy ito. If in case your battery is not that strong, mahihirapan ang starter mo to crank the engine. Tsaka malaking load ang compressor. That's why you should turn off the AC first before turning the engine off.
    Feb 2007
    #6735
    Anyone tried the services of malabon diesel? Ok ba? Honest? Affordable? How bout central diesel? Anyone can recommend a good calibration shop in marikina/cainta/antipolo/pasig area?
    Feb 2007
    #6736
    Pa-check ko tomorrow sabay na ng camber and alignment.
    #6737
    Parehong subok ma dito yan dalawang yan. Handa ka st least 20k para calibration mo.
    #6738
    Gusto ko rin nyan... hehehe
    Me pag kaka gastosan na naman hehehe.
    #6739
    Sa malabon diesel ako nagpagawa, ok naman. Kay berrima ok din
    #6740
    sir bg...
    may nagturo sakin noon... use degreaser or joy sa paglinis ng k&n then wd40 to re-oil..
    if gusto ng recharger kit naman.. meron ako 900php each.. hehe pickup timog/binondo/malabon (aerosol type napo.. iba kasi buhos type.. madami masasayang na oil and hindi pantay magiging application... hehe)
    hindi ko padin nililinis k&n ko since last yr.. hehe ni hindi ko pa sinisilip... madumi kaya talaga saatin? or over ang 40tkms na suggest ng k&n.. hehe
    sir cb...
    nasa magkano po gastos kay malabon pag calibrate palit injectors?
    nagpagawa po kasi ako nung 60tkms sa ibang shop(denso dealer).. mausok po and manginig gen2... pero parang walang nangyari.. di ko nafeel improvement.. cost yata was 15 to 20k.. nalimot ko na
    now malapit na mag 100k yung gen2... iniisip kong ipagawa uli.. or kahit sa 110/120k ipagawa ko na kaya? baka kasi wala nanaman improvement masayang lang...
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
