Page 1009 of 1435 FirstFirst ... 909959999100510061007100810091010101110121013101910591109 ... LastLast
Results 10,081 to 10,090 of 14348
    #10081
    On start-up mag b-blink yung a/t, pero once uminit na nawawala naman. Accdg. Sa mga aussie counter parts naten, draining the atf sump and cleaning the strainer is not enough. Need pa daw i flush out yung nasa atf cooler since around 40% pa ng atf natitira dun...
    Posted via Tsikot Mobile App
    Kaya dapat talaga once every 40k kms eh ipa-dialysis ang transmission natin. May kamahalan nga lang pero it is part of the maintenance ng ating sasakyan
    Apr 2010
    #10082
    Mga sir salamat ng marami malayo lang talaga ako sa city kaya mahirap sakin ang maintenance ko ng sasakyan dulo po ako ng quezon, this forum really helps me alot nagpapaluwas nalang ako ng tao para sa piyesa pag may nababasa ako na dapat ito at ganito mga ginagamit nyo sa ride muli salamat
    #10083
    Pero like all forums, me d.i.y. way kesa mag pa dialysis ... sa weekend pagawa ko sya...
    #10084
    Ohoy! Paano yang DIY na yan
    May 2010
    #10085
    Dito samen wala din dialysis... Planning to change my atf sana.. Ano kaya alternative?
    #10086
    Gusto nyo ba talaga malaman?;)
    Jun 2004
    #10087
    Wow pa share naman ng ATF Dialysis DIY na yan. On my AT rigs I interchange the dialysis and drain/refill with ATF filter replacement method - every 20k kms or 2 years whichever comes first. Mahirap malumaan ng ATF. By the way sa Fronte ako nagpapa ATF dialysis.
    #10088
    Meron manual nga nang DIY na ATF dialysis.
    Follow this steps.
    First you need to locate this hose para ma-drain yung ATF sa torque converter.
    1. Remove the hose shown in the illustration which allows the ATF to flow from the ATF cooler (built into the radiator) to the transmission. (this is the little u shaped one in the image above)
    2. Start the engine and discharge the ATF. Driving conditions: N range, idling
    NOTE
    The engine should be stopped within one minute of it being started. (tama lang ang 1 minute based on my experience, max na yan ha.) If the ATF has all been discharged before this, stop the engine at that point.
    Discharge amount: Approx. 3.8L-4.0 L
    3. Remove the drain plug at the bottom of the transmission case to drain out the remaining ATF.
    Discharge amount: Approx. 1.8L-2.0 L
    NOTE THIS IS THE TIME WHERE YOU CHANGE THE GASKET AND THE SCREEN FILTER IF YOU WANT TO. Ideally every 80,000kms you change this 2 items. This is also the time-consuming part.
    4. Install the drain plug with a gasket in between, and tighten it to the specified torque.
    Tightening torque: 39 ± 2 Nm
    5. Pour in new ATF through the oil filler tube.
    Amount to add: Approx. 6.0 L
    NOTE
    Stop pouring in the ATF once 6.0 litre has been poured in.
    6. Repeat the operation in step 2. (to pump out the rest of the contaminated transmission fluid)
    7. Pour in new ATF through the oil filler tube.
    Amount to add: Approx. 4.0L
    NOTE: Check for contamination or a burnt odor. If the transmission fluid is still contaminated or burnt, repeat Steps 6 and 7 before proceeding to Step 8.
    8. Connect the hose which was disconnected in step 1, and then securely re-insert the oil level gauge.
    9. Start the engine, and let it run at idle for 1 - 2 minutes.
    10. Move the selector lever to all positions once, and then return it to the N position.
    11.Check that the transmission fluid level is at the "COLD" mark on the dipstick. If the level is less than this, add transmission fluid.
    12.Drive the vehicle until the transmission fluid temperature rises to the normal operating temperature [70 − 80°C (158 − 176°F)], and then check the transmission fluid level again. The transmission fluid level must be at the "HOT" mark.
    #10089
    Technically you will need 11.5-12liters of ATF for this operation. Depende sa previous na nakalagay na ATF siyempre. Sa akin kasi 11.75L lang nagamit ko. So medyo kulang pala yung dati. Change the screen filet pero yung gasket natapon nang wife ko so gasmet maker na hi-temp ginamit ko. Okay din nama. No leaks so far. But I still recommend buying the gasket. Mura lang naman at every 80,000ks naman ang need talaga na palitan if religiously napapalitan ATF.
    Jun 2004
    #10090
    200k kms na Gen 2.5 ko! Still going strong after all this years.
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
