Results 10,091 to 10,100 of 14348
April 9th, 2014 11:39 AM #10091
Mas gusto yung D.I.Y. dialysis, kasi pede linisin yung strainer. Unlike sa machine if dun i dialysis and marumi yung strainer, after nun marumi pa rin ang strianer.
Tnx RT for posting di ko na mahanap yung Manual ko nyan... hehehe
- Jun 2004
- 476
April 9th, 2014 11:47 AM #10092Thanks RT sa info. Ill try this next time one of my AT equipped rigs is due for an ATF change. BG ako I interchange Dialysis method and simple drain and refill with ATF filter replacement. Importante malinis or mapalitan ang ATF filter
Posted via Tsikot Mobile App
April 10th, 2014 01:15 PM #10093
Mga sirs, saan ba ok na shop mag papalit ng ATF and magkano lahat ang damage?
- Jun 2004
- 476
April 10th, 2014 01:30 PM #10094If you're from QC you can go to Fronte in Banawe. Labor is P700 for Dialysis service. COmpute na lang for your ATF requirements para you have a fairly good idea of total cost.
April 10th, 2014 02:12 PM #10095
Thanks for posting that procedure Ry_Tower. That was very helpful.
For those who have bought and replaced their ATF filter, how much does one usually cost?
April 10th, 2014 04:03 PM #10097
a/t filter/strainer around P800 +/-
a/t gasket around P500 +/- (prices based on my receipts from Diamond Marcos Highway)
since we are into prices, post ko price ng underchassis parts (555 brand) for our reference (nagpapalit lang kasi ako)
im not sure if mura or mahal, sa suking auto supply lang kasi ako bumili nyan
1. lower balljoint P950 each
2. upper balljoint P850 each
3. tierod inner P700 each
4. tierod outer P 500 each
April 10th, 2014 06:37 PM #10099
- Aug 2006
- 10
April 11th, 2014 09:06 PM #10100Naka back read na ako at na paka interesting ng mga topics about pajero,got my 2001 fieldmaster recently at plan ko pa check kay sir Joseph,taga Laguna kase ako at well respected siya sa forum.Plan ko bumili ng float charger to maintain my battery if not in use,ask ko lang kung ok ito sa Motolite excel.Thank you at medyo OT .
byd seal5 dmi. that coolant tank is the same setup like in the fords. plastic coolant lines :twak2:...
BYD Philippines
