Results 1 to 10 of 27
- Sep 2003
- 7
July 23rd, 2004 10:33 AM #1hi guys!
saw this mitsubishi RVR (Japan Import Used Car).. do you guys have any feedback about this car? i am planning to get one kse...
thanks!
- 10,620
Tsikot Member Rank 3
- Oct 2003
- 734
July 23rd, 2004 12:50 PM #4pag may nakita kang ganun sabihan mo driver pre ang cute ng kotse mo ha tignan nga natin kng papalag sa oto ko one shot lang sa highway rekta. kwento mo nalang samin kng ano nangyari mukha kasing mabagal eh...
July 23rd, 2004 12:58 PM #5
matulin din pare. akala ko nga dati diesel yung RVR na may intercooler turbo na badge. gas pala.
http://english.auto.vl.ru/catalog/15731/
ewan ko kung yan yung inooffer dito sa subic. siguro selected units only?Last edited by ssaloon; July 23rd, 2004 at 01:05 PM.
July 23rd, 2004 12:59 PM #6
I plan also to get before but I doubt the spare parts availability locally. So I emailed Mitsubishi and they confirmed that they are not supporting RVR and Chariots MX, though they look like Spacewagon. Pero they can order daw spare parts sa Japan in case papagawa sa kanila.
- Jun 2004
- 135
July 23rd, 2004 01:49 PM #7If u ask me, di ako bibili any model na galing subic na converted, especially RVR, Estima, Delica etc. etc. You know why? Kasi banggain ka o ikaw man ang bumangga, im sure tengga agad car mo waiting for replacement parts at x2, x3 pa siguro presyo kung order from japan, swerte mo kung may makikita ka agad dito. And one thing more CUT & WELD lang mga yan what if kung hatawan na sa takbuhan nawalan ka ng GIYA dahil naputol ang welding, swerte mo kung BALDADO ka lang, eh kung RVR mo maging RIP, yare. Buy ka na lang ng local dami naman low mileage dyan, di pa sakit ng ulo.
July 23rd, 2004 02:27 PM #8
Depende sa pag kaka convert make sure na Original left hand drive steering parts kailangan ipataas mo yan unit na kukunin mo.
Most people are now aware of the basic facts about Japanese used cars:
Japanese cars made for the demanding domestic market are always designed to higher specifications than export versions. While in Japan, they were well looked after and driven at restricted speed on excellent roads.
Nevertheless, due to Japan's unique social & economic constraints, used vehicles depreciate faster here than anywhere else and can be purchased at amazingly low prices.
Superb automobiles, beautiful countryside and
Unfortunately, congested urban areas, overpriced toll roads and tight holiday schedules take most of the fun out of long distance car travel. This explains why most Japanese used vehicles usually come with low mileages.
An efficient rail and subway transportation system is always favored for daily commuting, and the SHINKANSEN (bullet train) takes care of more serious traveling needs.
Consequently, having been through less use & abuse, the overall condition for cars of similar age will be considerably better in Japan than in most other countries.
Tuned-up performance units & SUV of tremendous capabilities are never used to their potential and routinely spend an entire life in extended neighborhood use and proudly displayed on courtyards.
Strictly enforced speed limits of 30km/h in urban areas, 50km/h on highways and 80 to 100km/h on toll roads, help produce a pool of low mileage vehicles. Vandalism & car theft being virtually unknown in Japan, alarm systems are extremely rare on Japanese cars.
On the other hand, features such as power steering, windows & mirrors, climate control, car stereo, ABS and airbags are increasingly considered standard equipment.
- Jul 2004
- 3
July 23rd, 2004 03:00 PM #9Originally posted by diced
hi guys!
thanks!
GENERAL
Body type MV&1Box
Drive FULL 4WD
Transmission 5 speed manual
Displacement, cc 1997
Frame E-N23W-SNGF
Price of new car, thousands yen (Tokyo area) 2345 (~$19500)
SPECIFICATION (SPECS)
EXTERIOR
Exterior dimensions (LxWxH), mm 4320 x 1695 x 1690
Interior dimensions (LxWxH), mm 1880 x 1460 x 1140
Wheel base, mm 2520
Treads (F/R), mm 1455 / 1460
Ground clearance, mm 170
Curb vehicle weight, kg 1420
Gross vehicle weight, kg
Seating capacity, persons 4
Doors number 4
Min.turning radius, m 5.1
Fuel tank capacity, l 55
ENGINE
Engine model 4G63T (turbo intercooler)
Max.power (Net), kw(PS)/rpm 230 ps (169.17 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm 29.5 kg*m (289.30 N*m) / 2500 rpm
Power density 6.17
Engine type Serial 4 cylinder DOHC16 valve IC turbo
Engine information
Fuel system ECI-MULTI (electrically controlled gasoline injection)
Turbocharger Turbo with intercooler
Fuel type Unleaded premium gasoline
LEV system (Low emission vehicle) No
Compression ratio 8.5
Bore, mm 85
Stroke, mm 88
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 10
Fuel consumption at 60 km/h, l/100km
CHASSIS / TRANSMISSION
Power steering Yes
Tires size, front 205/65r15 94h
Tires size rear 205/65r15 94h
Braking system, front Ventilated disk
Braking system, rear Disk
Suspension system, front McPherson strut type coil spring
Suspension system, rear Semi trailing arm / coil spring type
- Oct 2003
- 734
July 24th, 2004 09:38 AM #10tama sabi nun isang poster mabilis nga yan pero hwag mo sagarin dahil konverted lang yan baka bumigay yun front yari ka. in case bibili ka stignan mo maigi yun pagkakakonvert.
i read somewhere, that if the paint is original factory, there should be no problem when removing...
Removal of Rain Visor and Chrome Door Handle and...
