Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    hi guys!
    saw this mitsubishi RVR (Japan Import Used Car).. do you guys have any feedback about this car? i am planning to get one kse...
    thanks!
    pm mo si hybrid, alam ko may RVR siya
    4G63T power! :fire:
    Oct 2003
    pag may nakita kang ganun sabihan mo driver pre ang cute ng kotse mo ha tignan nga natin kng papalag sa oto ko one shot lang sa highway rekta. kwento mo nalang samin kng ano nangyari mukha kasing mabagal eh...
    matulin din pare. akala ko nga dati diesel yung RVR na may intercooler turbo na badge. gas pala.
    http://english.auto.vl.ru/catalog/15731/
    ewan ko kung yan yung inooffer dito sa subic. siguro selected units only?
    Jun 2004
    I plan also to get before but I doubt the spare parts availability locally. So I emailed Mitsubishi and they confirmed that they are not supporting RVR and Chariots MX, though they look like Spacewagon. Pero they can order daw spare parts sa Japan in case papagawa sa kanila.
    Jun 2004
    If u ask me, di ako bibili any model na galing subic na converted, especially RVR, Estima, Delica etc. etc. You know why? Kasi banggain ka o ikaw man ang bumangga, im sure tengga agad car mo waiting for replacement parts at x2, x3 pa siguro presyo kung order from japan, swerte mo kung may makikita ka agad dito. And one thing more CUT & WELD lang mga yan what if kung hatawan na sa takbuhan nawalan ka ng GIYA dahil naputol ang welding, swerte mo kung BALDADO ka lang, eh kung RVR mo maging RIP, yare. Buy ka na lang ng local dami naman low mileage dyan, di pa sakit ng ulo.
    May 2004
    Depende sa pag kaka convert make sure na Original left hand drive steering parts kailangan ipataas mo yan unit na kukunin mo.
    Most people are now aware of the basic facts about Japanese used cars:
    Japanese cars made for the demanding domestic market are always designed to higher specifications than export versions. While in Japan, they were well looked after and driven at restricted speed on excellent roads.
    Nevertheless, due to Japan's unique social & economic constraints, used vehicles depreciate faster here than anywhere else and can be purchased at amazingly low prices.
    Superb automobiles, beautiful countryside and
    Unfortunately, congested urban areas, overpriced toll roads and tight holiday schedules take most of the fun out of long distance car travel. This explains why most Japanese used vehicles usually come with low mileages.
    An efficient rail and subway transportation system is always favored for daily commuting, and the SHINKANSEN (bullet train) takes care of more serious traveling needs.
    Consequently, having been through less use & abuse, the overall condition for cars of similar age will be considerably better in Japan than in most other countries.
    Tuned-up performance units & SUV of tremendous capabilities are never used to their potential and routinely spend an entire life in extended neighborhood use and proudly displayed on courtyards.
    Strictly enforced speed limits of 30km/h in urban areas, 50km/h on highways and 80 to 100km/h on toll roads, help produce a pool of low mileage vehicles. Vandalism & car theft being virtually unknown in Japan, alarm systems are extremely rare on Japanese cars.
    On the other hand, features such as power steering, windows & mirrors, climate control, car stereo, ABS and airbags are increasingly considered standard equipment.
    Jul 2004
    Originally posted by diced
    hi guys!
    thanks!
    specs of the 63T equipped rvr AKA x3
    GENERAL
    Body type MV&1Box
    Drive FULL 4WD
    Transmission 5 speed manual
    Displacement, cc 1997
    Frame E-N23W-SNGF
    Price of new car, thousands yen (Tokyo area) 2345 (~$19500)
    SPECIFICATION (SPECS)
    EXTERIOR
    Exterior dimensions (LxWxH), mm 4320 x 1695 x 1690
    Interior dimensions (LxWxH), mm 1880 x 1460 x 1140
    Wheel base, mm 2520
    Treads (F/R), mm 1455 / 1460
    Ground clearance, mm 170
    Curb vehicle weight, kg 1420
    Gross vehicle weight, kg
    Seating capacity, persons 4
    Doors number 4
    Min.turning radius, m 5.1
    Fuel tank capacity, l 55
    ENGINE
    Engine model 4G63T (turbo intercooler)
    Max.power (Net), kw(PS)/rpm 230 ps (169.17 kw) / 6000 rpm
    Max.torque(Net), N*m(kg*m)/rpm 29.5 kg*m (289.30 N*m) / 2500 rpm
    Power density 6.17
    Engine type Serial 4 cylinder DOHC16 valve IC turbo
    Engine information
    Fuel system ECI-MULTI (electrically controlled gasoline injection)
    Turbocharger Turbo with intercooler
    Fuel type Unleaded premium gasoline
    LEV system (Low emission vehicle) No
    Compression ratio 8.5
    Bore, mm 85
    Stroke, mm 88
    Final gear ratio
    Fuel consumption at 10-15 modes, l/100km 10
    Fuel consumption at 60 km/h, l/100km
    CHASSIS / TRANSMISSION
    Power steering Yes
    Tires size, front 205/65r15 94h
    Tires size rear 205/65r15 94h
    Braking system, front Ventilated disk
    Braking system, rear Disk
    Suspension system, front McPherson strut type coil spring
    Suspension system, rear Semi trailing arm / coil spring type
    Oct 2003
    tama sabi nun isang poster mabilis nga yan pero hwag mo sagarin dahil konverted lang yan baka bumigay yun front yari ka. in case bibili ka stignan mo maigi yun pagkakakonvert.
    4g63T pala yan.. parang ok na project car sa mga gustong kumarera ah
    May 2004
    Matulin RVR parang yung makina ng EVO sinaksak dyan sa RVR. Pataas mo bago mo bilin or magsama ka ng marunong sa steering. Yung mga nag 4X4 usually marunong tumingin yan kung welded lang and binaliktad yung RHD assembly.
    Oct 2003
    di mo kasi mapapansin yan RVR na malakas kasi karamihan nagdadadrive nyan slow-mo ang dating at di maangas .... mukhang stable sya ksi quite heavy yun body (small version ng space wagon) so assuming na hindi kinonvert yan i dnt mind ibanat yan sa highway
    Jan 2003
    hmmm...I haven't seen setup versions like that. But I do know that they are really fast fast fast. maganda ngang project car iyan. how much do they cost right now?
    Apr 2004
    Oo nga, dont buy.....You're also killing our auto industry. Lets admit na di ganung kadami yung mga models na nilalabas dito pero bakit nyo iinvest yung money mo sa 2nd hand na converted na nilaspag sa Japan? Takot din ako baka madedbol ako. Nakasakay nako sa 3dr Pajero ng friend ko. Kinakabahan ako kasi hinahataw nya, baka bumigay. Ayun, binenta na nya pero nahirapan niya ibenta ito.
    Dec 2002
    hello!
    i would like to share some information about my rvr. i have a gas non turbo awd version and frankly i'm very happy with it! it's fast and very easy to drive. it has great leg room for a small car and so far i have had no problems with it. my only wish is that i got the turbo version instead. i had the conversion inspected again for my peace of mind and the mechanic gave it a thumbs up. my friend has a turbo version he told me that he raced an evo lancer once out of town and the guy was so dumb founded why he couldn't shake of his rvr. its quite thirsty though at 6km to a liter city driving. i heard the diesel versions do about 11km to a liter. another thing, hope i can find a surplus space wagon dashboard coz mine is ugly. anyone have an idea where i can get one? thanks
    Dec 2002
    hello!
    pls check out my thread regarding the rvr
    thanks
    Jul 2005
    OK naman ang RVR so far,I have same but 2.0 cc 4D68 TDIC engine.ok ang engine walang usok.malakas din arangkada kaya lang takaw sa diesel.excellent ang riding comfort & suspension stable na stable kahit sa kurbada .properly insulated pa walang ingay marinig sa loob.like a rally car hehehe...
    Neg feedbacks:
    1. right side mirror not set properly.Wrong angle
    2. head beam light sa low baliktad.nasisislaw ang kasalubong
    3. wiper unit not accurately aligned sa w.shield but already rectified
    4. takaw sa diesel( don't know with gas)
    5. mahirap daw hanapin ang parts
    wala naman major welding re-connection kasi rack type ung power steering ass'y nito hindi gear box type..binaliktad lang ang position with the same mechanical linkages.
    check molang maigi ung unit lalo na sa dashboard area maraming naka condemed.pero sa akin pina set up ko na ng maayos including aircond ducts and ventilators.ung digital auto climate air cond control nya pina balik ko sa original circuit kasi dati naka recta lang.
    generally i love my rvr kaya lang problema un future maintenance nito kasi mahirap daw hanapin ang parts.
    Apr 2004
    Quote Originally Posted by jeegoogs
    Neg feedbacks:
    1. not set properly kasi pang rhd angle yung side mirror.
    2. same with #1, rhd settings kasi.
    Aug 2004
    I don't see what's the biggie. Why don't people get the Spacewagon? More space, and it's still fun to drive, even in 1.8 liter trim.
    These are nice cars, para ngang Lancers with wagonbacks on them.
Merged: Mitsubishi RVR
