Page 16 of 205 FirstFirst ... 61213141516171819202666116 ... LastLast
Results 151 to 160 of 2048
    Apr 2009
    #151
    tama ka horsepower!
    inggit lang ako sa unit ng iba na walang problem hehe
    hay... kaya sabi nila enjoy the ride
    May 2008
    #152
    Quote Originally Posted by JJGF View Post
    bro easyman, mukhang tayong dalawa lang ang minalas sa unit natin ah hehehe
    issues ng MS ko:
    - idling problem
    - dragging sa 1st to 2nd gear when in "D"
    - dragging when braking from 10kph - 0kph
    - jerking problem 2nd gear to 1st gear pag paakyat ng carpark
    - wheel alignment and camber
    - bubbles sa reflector ng left foglight... parang kumulo sa init (replaced)
    sana hanggang dyan na lang hehehe
    Hala!! we have the same problem bro. we need to compare notes. i am being managed by cas C5. How about you?
    #153
    Quote Originally Posted by kapitan_dukot View Post
    Sir Lancelot,
    Regaring the noise sa brakes, baka marumi lang po yung brakepads or something. Nalubog po ba kayo sa baha recently?
    As for the wiper, napag usapan din po yan previously (either on this thread or the main Montero Sport thread). Some owners have said that this "garalgal" effect only happens in the early part of the wiper blade's life, and will disappear as you use the wiper more. Other owners have decided to replace their wipers altogether, which eventually eliminated the sound.
    I belong to the second group. Had my wipers changed to the banana-type ones. No more noise when using my wipers.
    sir anu po ba yun banana type?
    #154
    hi
    based on what i read here, If I have enough money i will go for Ms 2.5 4x4 MT. because the 2.5 engine has a good rating compare to 3.2.
    The 2.5 is released in uk but the 3.2 is not, because of emission, as what I read in honest john website the 2.5 is a euro 4 compliant but not the 3.2. Correct me guys if Im wrong. . and according to car advice website the 3.2 engine is more noisy than the 2.5.
    I drive 3.2 Mt Strada and it has a lot of power, so for transmission problems, hirap tlga pag automatic kaya we bought the MT, it last longer =)
    these are my opinions lang
    #155
    Quote Originally Posted by marktriton View Post
    Sir medyo mahirap i-explain, pero basically yung banana type is parang all-rubber na wiper blade. Wala na yung metal frame that you see on conventional wipers. Supposedly mas maganda ang hagod niya sa screen kasi mas even ang pressure across the entire blade, unlike sa traditional wiper na uneven.
    Hope I was able to explain it well sir. Try niyo rin mag search about banana type wipers dito sa forum. I'm sure meron nang nag explain niyan in the past, and malamang mas accurate ang description nila...
    #156
    Kap is right. it is made of all rubber material. Mas magaan ito when i compared it with the OEM with metal frame.
    Apr 2006
    #157
    hi
    3.2 4M41 engine
    - Timing Chain
    - Noisier Idling sound
    2.5 4D56 engine
    - Timing Belt
    - Noisier igniton sound
    #158
    Quote Originally Posted by lancelot View Post
    Hello,
    I own a ms GLS SE bought last month, i notice that upon riding the montero, when you press the brake half way there is a screeching sound on the brakes.
    My montero is only 300 kms but after 2 to 3 sounds it disappears only on first use after you ride it. It is very annoying. It gets me irritated everyday to hear this sound from the brakes considering my mileage is less than 300 kms.
    Also my wiper blade is so noisy it vibrates all the time, i have to put rain x on the glass because it is really sticky, is this defective?
    Do you guys experience this also.
    Thanks
    SIr san dealership niyo po nabili yung unit niyo?
    #159
    issues ng MS ko:
    - idling problem
    Sir tanong ko lang po kung ano klaseng unit yung ms niyo? 2.5 or 3.2 SE? at san dealership niyo po nabili?
    #160
    ok bro nice explanation, i Got it
ISSUES FOR THE MONTERO SPORT. Please post them here.
