Results 181 to 190 of 2048
Threaded View
- May 2008
- 290
April 18th, 2009 11:55 AM #1Here are mine:
1. When you start the engine, you feel (more often than not) a thud as if the engine hits the chasis or the body.
2. When running with auto, the auto upshift gear is felt by a dragging feeling as if "nabitin" ang shift. Note, it is not the downshif (which is normal). but i do understand that the auto transmission will downshift if you push the accelator pedal down. I recommmned you to use the sportronic manual shift for GLS SE.
3. The engine is too noisy at 1500 rpm.
4. Do not put the standard rear spoiler. It will only create an acumulation of dirt on the rear mirror/window
Edsa is about 24kms long. So, 15b / 24 is approx 625m per km?
EDSA Rehab/Rebuild and Guadalupe Bridge Repair
