Page 203 of 205 FirstFirst ... 103153193199200201202203204205 LastLast
Results 2,021 to 2,030 of 2048
    Jul 2004
    #2021
    Quote Originally Posted by waver View Post
    Hehe you are the first to say (at least as I can recall) that wala naman masyado issues si Montero.
    That's good to hear though. Meron din naman cguro monty units that had bearable maintenance costs and minimal problems.
    Sent from my CPH2043 using Tsikot Forums mobile app
    Never had any major issues with my Monty GTV during my 11 years of ownership.
    Only major expenses/issues I recall were tires (when replacing all 4), battery, steering wheel controls do not function anymore, no more batteries on the TPMS tire receivers, front wiper water noozle needed constant clearing to ensure a good spray, and no map update for the GPS unit.
    Another major expense was the timing belt and related parts change (this is expected). Aircon was not an issue although during heavy traffic, it would lose its cool but once it was moving again, it became cool again.
    #2022
    Just had 90k kms pms at mmpc q ave (gateway cebu operated) done for our previous gen Montero. Taas nandin ng PMS kung hindi lang change oil but every 3 years lang plan gawin sa mmpc so it cushions the blow at least.
    Nakakwentuhan ko service advisor about current gen Montero.
    Per update sa akin, mga 50% ng issues is concerning power tail gate (pinipilit manual kaya nagkakaerror, operating power tailgate while in drive yung transmission, and electronic parking brake issue - usually nangatngat daw wiring)
    Oct 2014
    #2023
    Hi, seeking insight on transmission fluid (AT) change. Ive read service booklets and they say the same, change transmission fluid every 40,000 Km. (Unless I have missed it) there is no time span.
    Problem: I have low mileages (e.g. 20,000Km for 6+years)
    Does that mean I'll probably need to change AT fluid after another 6years? Or is there like an "every x years whichever comes first?
    Thoughts welcome =)
    #2024
    Thoughts welcome =)
    Replace it na. Usually 100k kms naman palit talaga but ako personally 3 years papalitan ko na rin.
    If you have low mileage ganun pa rin alam ko buhay ng ATF 5 years lang talaga.
    It's cheaper to replace ATF than the transmission
    #2025
    i will agree that you replace the atf already. 6years is already long ang saving grace mo lang is the low mileage. think of it this way sobrang nasulit mo na ying current atf and more. luckily wala namang seemingly ill effect yung prolonged useage.
    #2026
    Thoughts welcome =)
    as with what others said, better change ATF na.
    for reference as to what a possible "time equivalent" to the mileage indicated in the service booklet. Here, casa usually computes it as 5k every 3 mos, 10k every 6mos or 20k every year ang "normal" usage, or equivalent to 2 years.
    So, even on the low side of 10k every year to give some leniency of "life" of oil, 4 year interval, if that is what's recommended by the booklet na every 40k. Pero just projecting it lang. Since 6 years ka na, even on the generous computation na 4 year interval, lagpas na din yung life ng ATF mo. =)
    Apr 2012
    #2027
    Thoughts welcome =)
    agree with others na better palitan na ang atf at filters. if not keen on changing then at least replace the filter and top-up sa proper level.
    Sent from my SM-G960F using Tsikot Forums mobile app
    Sep 2021
    #2028
    Even for vehicles with those so called “lifetime fluids” pinapalitan din dapat, because there’s really no such thing.
    Meron, in the sense that manufacturers design vehicles to last mga 8-12 years lang, on average. (Aba syempre, so you keep buying cars kung di mo pagsawaan) Yung 8-12 years na yun yung “lifetime” na never mo palitan yung fluid because they expect you to send it to the scrapyard by that time na
    Oct 2014
    #2029
    Actually, the reason I asked the forum is because low mileage ako, but I DO feel na hindi kasing smooth yung shifting of gears unlike before.
    Yung CASA checks it naman wala silang sinasabi I expected them to tell me to change when needed..
    In any case, yes this Saturday, I'll include changing ATF na sa PMS..
    Thanks guys!
    #hehe I assume you'll say the same about tires, need to change na din
    #2030
    Thanks guys!
    Tires max 6 years din kahit gaano pa kakapal palitan mo na.
ISSUES FOR THE MONTERO SPORT. Please post them here.
