Results 1,921 to 1,930 of 2048
Tsikot Member Rank 1
- Jul 2009
- 4,090
February 25th, 2020 07:59 PM #1921
- Oct 2014
- 1,235
- Aug 2008
- 26
February 26th, 2020 02:20 PM #1923
- Mar 2020
- 1
March 2nd, 2020 12:38 AM #1924
March 2nd, 2020 03:12 AM #1925
yes, its normal. its about the adaptive transmission control feature. kapag na sense ng ecu na madalas preno at pag-menor sa downhill/uphill, mag-activate yung adaptive control at mag steady sa 2nd gear. to reset, briefly shift sa neutral then back to sports mode. o kaya naman tumabi if safe to do so, switch off then on the engine.
- Aug 2008
- 26
March 3rd, 2020 10:50 AM #1926
March 3rd, 2020 01:34 PM #1927
afaik, merong wala na MAF's
kung may rattling, hindi maganda pagka-fixed sa support. pwede mo i tighten yung mga bolts sa supports o kaya talian ng plastic cable ties yung air intake duct to secure. base sa picture mo, i encircled yung maf sensor na tinatanong mo
- Aug 2008
- 26
March 3rd, 2020 04:03 PM #1928Yup sir monty_gtv. Walang ganyan MAF sensor yung sa akin.yung isang klaseng air filter box yung ssa akin yung pinaka duct nya sa may ibabaw ng radiator doon nag rattle.yung ganyang air filter box kaya pwede iligay sa unit ko pala wala ng rattle.isa pa pala po sino kaya ka experience na langingit sa may dash para kasing may bubwit.
sa may stero panel or sa mga usb port.
March 3rd, 2020 05:05 PM #1929
i see, so yung unit mo belongs sa wala ng MAF. thats no a big deal naman. maybe the designers find it redundant or put a internal sensor somewhere to function the same.
about sa rattling ng air duct, ganyan din sa unit ko dati, cable tie lang solusyon diyan. itali mo sa nearby sturdy component para hindi gumalaw at magkarattle. nakaangat kasi ng konti yung dulo sa ibabaw ng radiator cover. inserting a thin foam also helps, ensure lang na nakadikit maigi.
rattling ng dashboard ay very irritating at mahirap mawala at saka if old na yung unit, what can you expect? nakukuha yan if binaklas ang dash and hindi naibalik ng maayos. any car audio shop with knowledge in car stereos can dismantle/reassemble and tighten loose parts if necessary.
- Mar 2020
- 6
March 4th, 2020 06:31 PM #1930Share ko lang admin kung pwede, pakidelete kung hindi.
Sa mga Montero Owners po (Gen 2) na me problema sa Rear AC button nila (ayaw umilaw), meron po akong DIY solution. Para lang po makatulong.
Paano Ayusin ang Pundidong Rear AC Button ng MonteroSports? | Complete Guide - YouTube
Salamat
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
