Results 1,751 to 1,760 of 2048
January 23rd, 2018 12:00 PM #1751
Maybe they did not run simulation on the unit to see how it will be on all dates....
My guess, in the code they used a short integer or integer in the variable definition which they used in the date function. And so, at one point it will hit the maximum short integer or integer value and it goes to never never land.
So the fix in the code is just to change in the variable definition to long integer and it will be practically forever for the date....
- Jan 2018
- 1
January 24th, 2018 07:31 AM #1752
- Jan 2018
- 1
January 26th, 2018 10:03 AM #1753
- Jan 2018
- 3
January 26th, 2018 11:05 AM #1754
January 26th, 2018 01:23 PM #1755
My head unit just got fixed.
Winterpine personnel uploaded a software update.
- Mar 2007
- 109
January 26th, 2018 01:28 PM #1756Where did you have your unit fixed? At the casa?
Sent from my RNE-L22 using Tsikot Forums mobile app
January 26th, 2018 01:42 PM #1757
- May 2017
- 2,128
January 29th, 2018 03:13 PM #1758Count me in too sa Montero 2013 namin, nag-iiba din ang Date every time I'm turning on the vehicle.
Guys another question. My GPS is now showing "Application error" application navigation.exe is experiencing trouble and will shutdown blah blah. Do you know how to solve this issue?
January 29th, 2018 03:15 PM #1759
Mga tsips, sino na nagpalit dito aircon compressor? May ugong na yung sa akin after magtanggal ng shim, palitin na daw sabi nung technician.
- Aug 2017
- 3
February 2nd, 2018 12:36 PM #1760PTP: baka may makatulong na experience ko sa montero ko 2013 GLS V model habagng tumtakbo ko sa slex 90-100kpg biglang nag jerk then yung gear indicator nya pag check ko nagbiblink na yung "D" then ayaw na mag accelerate. pero nung pinatay ko ok na ulit. pero napansin ko ngayn kapag natakbo na ng 90 pataas parang sinisinok. nagpalinis nko ng EGR ano pa kaya possible na problema?
Working na MMDAs. MayHulika. Only for NCAP violations
SC (temporarily) stops NCAP
