Page 186 of 205 FirstFirst ... 86136176182183184185186187188189190196 ... LastLast
Results 1,851 to 1,860 of 2048
    Dec 2013
    #1851
    Anyone experienced stripping or loose thread on their engine oil drain plug?
    #1852
    i don't monty, but
    yes. easily. when the person over-tightens and/or over the course of the years..
    but i think there is an attachment that can remedy it.
    i just do not know how good the fix is.
    Aug 2018
    #1853
    3rd gear was replaced or was it the clutch?
    'Yung mismong gear daw, buwan nga po inabot kakahintay sa gear.
    Jan 2008
    #1854
    Quote Originally Posted by BillyTangad View Post
    Popping out of gear.. sa mga lumang jeepney ko lang nakikita yan..maybe isolated case.. pero very rare yan lalo na medyo bago pa.monty
    Sep 2018
    #1855
    Quote Originally Posted by Geronimo Valino View Post
    non monty, my ATF drain plug loosen, with slight leak.. mechanic replaced the loose thread bolt.
    Oct 2018
    #1856
    Hi, guys.
    I need recommendations kung san pwede magpatingin ng electronics ng Montero 2015?
    problem ko kasi nagloloko ung alarm ko di ko sure kng ung alarm ang may problem or yung wiring/electronics ng sasakyan tapos naapektuhan nln ung alarm system.
    Alarm system problem:
    1. parang lagi syang nagrerestart, nag lock and unlock kulang ung blink ng ilaw, dati 2 blinks pag lock and 2 beeps, pero ngayon parang nabibitin sya (btw, bagong palit na yung battery)
    2. pag nag bbreak ako sya mostly na ttrigger tumunog, parang startup na tunog ng alarm system
    thank you po!
    Aug 2013
    #1857
    Brake sana tatapakan ko, pero natapakan ko yung gas unintentionally, suddenly umandar yung kotse.
    Quote Originally Posted by brainiac07 View Post
    Hi, guys.
    thank you po!
    patingin mo ke zix performance.
    Oct 2018
    #1859
    Thanks sir!
    Btw, yung stock TPMS ko po walang data na lumalabas after mapalitan ung battery ko, puro dash lang - - ung naka display sa head unit dati number. Pano po ba mag reset ng TPMS?
    Jun 2009
    #1860
    ok nga iyan sa yock's. i had my alternator refurbished there before. it's still operating very well several years after.
    Same here. Alternator refurbished by Yock's still in very good condition after 3 years.
ISSUES FOR THE MONTERO SPORT. Please post them here.
