Results 1,761 to 1,770 of 2048
February 2nd, 2018 02:00 PM #1761
^ most likely faulty scv or inhibitor switch. if nasa manila ka, try mo sa zix performance shop
- Aug 2007
- 26
February 23rd, 2018 06:38 PM #1762firmware/map update?
anyone brave enough to try resources from this link to maybe solve the clock issue? looks like it contains firmware/map updates for the different models...
Directory listing of http://www.inavcloud.com/portal/
also experiencing the same clock problem on my hu (2012 MMS GLS-V A/T)
i think iNav is the one in Aurora Blvd mentioned in one previous post in this thread...part of the Winterpine group...
- Oct 2008
- 113
February 25th, 2018 11:24 AM #1763Hi, did you guys had an issue on the maintenance service display after pms done on a dealership? It seems it’s stuck at 15k km when they’ve reset it for the next pms. They’ve used a laptop to set it but i think it wasn’t done the right way. Before i could adjust it by just pressing the multifunctional button.
March 9th, 2018 07:14 AM #1764
Anybody here solved their clock issues on their gen 2 head units?
- Mar 2006
- 13
March 9th, 2018 08:57 AM #1765
March 9th, 2018 04:45 PM #1766
^ Ah ok. So meron na din pa lang solusyon sila. Will check the casa nearest to us soon. Tnx!
March 9th, 2018 06:52 PM #1767
Same here. Took less than 15 minutes basta may Winterpine technician sa casa.
Basically, they: 1) remove your sd card; 2) put in their sd card with the software update; 3) install the update; and 4) put back your sd card
My clock now runs fine.
Reading on my TMPS seems more detailed now. Before it reads up to only the tenth place value most of the time like for example 32.6. But now it always reads up to the hundredth place value like 32.67 and reading up to the tenth place value is more of an exception than the rule
- Jun 2012
- 4,447
March 9th, 2018 09:09 PM #1768
- Mar 2018
- 4
March 10th, 2018 06:27 PM #1769
March 10th, 2018 09:21 PM #1770
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
