Results 751 to 760 of 2048
- May 2008
- 290
February 27th, 2011 11:22 AM #751
February 27th, 2011 12:42 PM #752
- Oct 2007
- 25
March 1st, 2011 11:26 PM #753Good Day to all. Ask ko lang kung may information kayo kung maglalabas ang Mitsu ng 4x2 MT VGT anytime soon.
Thanks and God Bless.
- Jun 2008
- 52
March 2nd, 2011 03:12 AM #754tried hydroplaning (unintentionally) at the glorietta 4 parking lot. kept the nose forward and turned the steering wheel in the same direction. no spin outs naman thankfully. the car wash boys jumped out of the way but luckily nobody was hurt and no car was damaged.
i felt the tires losing grip (kinda like drifting - driving with the car going sideways). from what i know, after going through the wet surface, the car would spin out upon reaching the dry land as the tires were spinning freely during the "wet phase". but fortunately, the wheels didn't spin and immediately gained traction. the wheels that didn't have control seemed to have gained them back immediately. do i have the LSD to thank for that?
whatever it is, the monty's LSD works and probably saved me a lot of money by not hitting the parked cars. drifting is hard to control in itself. losing control in a full parking lot with narrow lanes is probably harder to correct.
March 2nd, 2011 04:46 PM #755
The 4x4's have LSD. All models have ABS which allows you to both mash the brakes brainlessly and still turn the vehicle. Use it to your advantage.
- May 2008
- 290
March 3rd, 2011 12:28 PM #756The sliding wheel will not continue to slide (Limitted slide) and shift the torque to the wheel with grip, then you have control. LSD is the way to go!!!!!
March 4th, 2011 02:11 PM #757
I wasn't aware that the GLS 4x4 M/T had a LSD (rear limited slip differential). I do know that the GLS SE 4x4 A/T has a hybrid type limited slip differential as does the new GT V.
Both M/T and A/T have a centre (between front and rear) differential with vicious coupling that apportions power % between front and rear (torque split proportion), and can also be locked up with the Super Select gear lever.
- Feb 2011
- 49
March 4th, 2011 09:57 PM #758Spoiler Benifits:
A specially designed rear spoiler could increase the fuel efficiency of minivans and SUVs, according to a new study detailed in Green Car Congress. The study reveals that such a spoiler could both reduce drag and nearly eliminate aerodynamic lift—effectively saving several miles per gallon worth of gas consumption.
The researchers used principles of fluid dynamics and ran numerical simulations in order to craft an ideal design for a spoiler specifically designed for bluff-backed vehicles. The study was published in the International Journal of Vehicle Design, and it found "that the aerodynamic drag and lift on a mini-van moving at 108 kph (67 mph) are reduced by 5% and more than 100%, respectively, when the new spoiler is attached to it."
And those numbers, especially the inconsequential-seeming 5 percent of drag relief, can add up to major fuel savings:
"65% of the power required for ground vehicles to travel on a highway at 70 miles per hour is being consumed due to aerodynamic drag, the reductions from the spoiler could increase fuel economy by up to several miles per gallon."
It should be emphasized how different this spoiler is from those we're accustomed to seeing on performance cars, and the small ones already installed on some SUVs and minivans—these spoilers may appear a little strange by comparison:
"Conventional spoilers resemble an inverted plane wing and generally work by increasing the downward force on the back of the vehicle as well as improving the flow of air across the bluff rear. The new rear spoiler resembles a wave in profile rather than a wing."
March 5th, 2011 04:04 PM #760
Yes, there is that button.
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
